Has liked: 165 times
Been liked: 849 times
Hi Brian
I do like your hull color - I think it looks just right. Are you going to fill any of the screw holes and add fake welds etc?
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Post by Brian Ostlind »
Robert E Morey wrote:
Wed Jul 11, 2018 10:41 pm
Hi Brian
Thank you Bob! The appearance changes dramatically with the clear coat. I presume it will go through more changes when I add filters over it after I ad camo. I am pretty torn about the welds. They look really good on the models I have seen on the forum but the paint I use is automotive and very thick I don’t know if the fine details will even render. I am more focused on the Zimmerit. It’s the only major mod I am planning to do. The welds take a lot of time too and I am really trying to hurry the build to make room for the FAMO.
Brian Ostlind
Actually, the real reason I am in a hurry is because I want to drive this thing!!!
You are right - welds are very time consuming. I would recommend filling some of the lower screw head recesses though - they will detract some on the look.
Wanting to drive the model and getting a FAMO are both great reasons to move along! :roll:
B
Brian Ostlind
HULL: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
TORSION BARS: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
WEATHERING: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Brian Ostlind
I used a bunch of pigments, and washes even crushed grass. I like this direction because it can be heavy and still look like a piece of equipment that has only driven a few hundred kilometers.
Has liked: 794 times
That's looking good Brian. How come you have not fitted the hubcaps also?
Brian Ostlind
Thanks Vince. That is the back of the ROADWHEELS. The fronts of the wheels are still unpainted. I wanted to assemble them completely before I painted the fronts so I can get the screw ends and nuts underneath the base coat.
Oops. My bad. Forgot that the hubcaps on those sets of wheels are the low profile ones.
Brian Ostlind
I am always confused with this many parts too. Trust me!
Brian Ostlind
RUNNING GEAR: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
When the wheels start getting installed it really starts taking shape.
Brian Ostlind
REFERENCES: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
