- Has liked: 135 times
- Been liked: 795 times
Hi Brian
I do like your hull color - I think it looks just right. Are you going to fill any of the screw holes and add fake welds etc?
- Brian Ostlind
- Has liked: 972 times
- Been liked: 2068 times
Thank you Bob! The appearance changes dramatically with the clear coat. I presume it will go through more changes when I add filters over it after I ad camo. I am pretty torn about the welds. They look really good on the models I have seen on the forum but the paint I use is automotive and very thick I don’t know if the fine details will even render. I am more focused on the Zimmerit. It’s the only major mod I am planning to do. The welds take a lot of time too and I am really trying to hurry the build to make room for the FAMO.Robert E Morey wrote: ↑Wed Jul 11, 2018 10:41 pmHi Brian
- Brian Ostlind
Actually, the real reason I am in a hurry is because I want to drive this thing!!!
You are right - welds are very time consuming. I would recommend filling some of the lower screw head recesses though - they will detract some on the look.
Wanting to drive the model and getting a FAMO are both great reasons to move along!
B
B
- Brian Ostlind
- Brian Ostlind
- Brian Ostlind
- Brian Ostlind
WEATHERING: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
I used a bunch of pigments, and washes even crushed grass. I like this direction because it can be heavy and still look like a piece of equipment that has only driven a few hundred kilometers.
- Has liked: 781 times
- Been liked: 1745 times
That's looking good Brian. How come you have not fitted the hubcaps also?
- Brian Ostlind
Thanks Vince. That is the back of the ROADWHEELS. The fronts of the wheels are still unpainted. I wanted to assemble them completely before I painted the fronts so I can get the screw ends and nuts underneath the base coat.
Oops. My bad. Forgot that the hubcaps on those sets of wheels are the low profile ones.
- Brian Ostlind
- Brian Ostlind
When the wheels start getting installed it really starts taking shape.
- Brian Ostlind
