Centurion 32
Ray Brown
Has liked: 26 times
Been liked: 103 times
Centurion 32
Post by Ray Brown »
G'day. I've dry assembled 1 set of bogies for anyones reference if your confused by the drawings. To get the ball joints fitted I partly screwed the ball joint into the swing arm and used a bench vice to slowly squeeze the ball socket onto the ball joint. It was so easy. Pics attached.
cheers
Ray
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
G'day. I've found that the road wheels rub against the bogies if the axles are tightened per instruction book. Axle appears to be to short. Pics attached.
mick whittingham
Has liked: 10 times
Been liked: 226 times
Re: Centurion 32
Post by mick whittingham »
Ray,
The road wheels look to have been fitted wrongly, they should be fitted back to back on the outside of the hub. It looks as though you have sandwiched the hub between the pair of wheels which would make the inner one rub on the housing. Hope you have only done one pair as there are a lot of bolts to undo.
I fitted all my bogeys and the tracks yesterday as a dry fit and it moves beautifully along. I was so thrilled to see the hull move for the first time, brilliant engineering.
Regards, Mick
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
G'day Mck. Thanks for that. The beauty of sharing on the forum. i only put 4 bolts on 4 wheels. Whew.
Merry Xmas.
Ray
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
Has liked: 1038 times
Re: Centurion 32
Nice one Ray, good to see more Aussie Cents appearing. The glacis plate looks good. All the best Stephen
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
thanks steve. the glacis plate in cut from 7mm perspex. you wouldnt know it.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Re: Centurion 32
Post by Kevin Hunter »
Clever thinking Ray. Potentially solves many problems, like finding sheet aluminium (in the Channel Islands), the cost of postage if sourced in the UK mainland, not having the tools to work the aluminium and so on.
Your tank is coming together well, and looking good
Kevin
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
Wow. So long since I posted here. Well here are some pics of when I gave it a run at a friends house. Still not finished as in turret bin lids being fabricated, turret basket being worked on, etc but it drives, traverse, fires, recoils. So in between working on bits & pieces I run it whenever possible.
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
I've found some mesh, which was used in the snake cage that I've cut and zipped tied to the basket frame so that I can trim then solder. It really makes a difference to the tank.
Ray Brown
Has liked: 26 times
Re: Centurion 32
Post by Ray Brown »
some old updates. nothing special.
