G'day. I've dry assembled 1 set of bogies for anyones reference if your confused by the drawings. To get the ball joints fitted I partly screwed the ball joint into the swing arm and used a bench vice to slowly squeeze the ball socket onto the ball joint. It was so easy. Pics attached.
cheers
Ray
Centurion 32
- Has liked: 26 times
- Been liked: 103 times
Re: Centurion 32
G'day. I've found that the road wheels rub against the bogies if the axles are tightened per instruction book. Axle appears to be to short. Pics attached.
- Has liked: 10 times
- Been liked: 189 times
Re: Centurion 32
Ray,
The road wheels look to have been fitted wrongly, they should be fitted back to back on the outside of the hub. It looks as though you have sandwiched the hub between the pair of wheels which would make the inner one rub on the housing. Hope you have only done one pair as there are a lot of bolts to undo.
I fitted all my bogeys and the tracks yesterday as a dry fit and it moves beautifully along. I was so thrilled to see the hull move for the first time, brilliant engineering.
Regards, Mick
Regards, Mick
Re: Centurion 32
G'day Mck. Thanks for that. The beauty of sharing on the forum. i only put 4 bolts on 4 wheels. Whew.
Merry Xmas.
Ray
Merry Xmas.
Ray
- Has liked: 1024 times
- Been liked: 2094 times
Re: Centurion 32
Nice one Ray, good to see more Aussie Cents appearing. The glacis plate looks good. All the best Stephen
- Has liked: 598 times
- Been liked: 145 times
Re: Centurion 32
Clever thinking Ray. Potentially solves many problems, like finding sheet aluminium (in the Channel Islands), the cost of postage if sourced in the UK mainland, not having the tools to work the aluminium and so on.
Your tank is coming together well, and looking good
Kevin
Kevin
Re: Centurion 32
Wow. So long since I posted here. Well here are some pics of when I gave it a run at a friends house. Still not finished as in turret bin lids being fabricated, turret basket being worked on, etc but it drives, traverse, fires, recoils. So in between working on bits & pieces I run it whenever possible.
