88 parts
Forum for discussion relating to the 88mm Flak36
Online
Gary Richardson
Has liked: 713 times
Been liked: 1641 times
Re: 88 parts
Post by Gary Richardson »
Hi Phil
Superb workmanship, it's a real treat watching your build progress.
Gary
2021 Late Tiger 1 Abteilung 301 (Funklenk), 2022 Churchill Mk3 AVRE, 2x Czech Hedgehogs, 2024 Triple span Bailey Bridge, M26 Pershing.
Has liked: 2253 times
Been liked: 7126 times
Re: 88 parts
The handbrake lever has come together nicely, just got to replicate for the other end.
Hand filing the handles
Silver soldering
Silver soldering
Silver soldering
Silver soldering
That's about the height
When set up correctly the real thing didn't move that much, it was also power assisted from the air system powered from the on-board compressor in the kdfz7
The angle of the trigger will change to "more open" as I "fit" the parts, it's all a bit tight right now
And it functions
And it functions
Re: 88 parts
The air brake system
Air system isolation valve parts turned ready to be soldered
One little job is to replace the huge m3 fender bolts with m2 bolts, still too big but a compromise
Silver soldered isolation valve with mount, I'm using aluminium welding rod as the air pipe plumbing
The air cylinders are now joined with in and out pipe work
This tail end  pipe will have yet another air coupler courtesy of Mr Lewington
