88 parts
Forum for discussion relating to the 88mm Flak36
Gary Richardson
Has liked: 787 times
Been liked: 1878 times
Re: 88 parts
Post by Gary Richardson »
Hi Phil
Superb workmanship, it's a real treat watching your build progress.
Gary
Has liked: 2282 times
Been liked: 7196 times
Re: 88 parts
The handbrake lever has come together nicely, just got to replicate for the other end.
Hand filing the handles
Silver soldering
Silver soldering
Silver soldering
Silver soldering
That's about the height
When set up correctly the real thing didn't move that much, it was also power assisted from the air system powered from the on-board compressor in the kdfz7
The angle of the trigger will change to "more open" as I "fit" the parts, it's all a bit tight right now
And it functions
And it functions
Re: 88 parts
The air brake system
Air system isolation valve parts turned ready to be soldered
One little job is to replace the huge m3 fender bolts with m2 bolts, still too big but a compromise
Silver soldered isolation valve with mount, I'm using aluminium welding rod as the air pipe plumbing
The air cylinders are now joined with in and out pipe work
This tail end  pipe will have yet another air coupler courtesy of Mr Lewington
Re: 88 parts
The tow bar is milled from a solid billet of aluminium
Sketchy
Sketchy
Some careful work holding here
It's an awkward piece to hold as its tapered
Lots of filing
Lots of filing
Made from one solid piece of aluminium
There's an unusual bracket to make here
A couple of rivets here and there and the big lift handle to finish
Re: 88 parts
The draw bar detailing.
Handles made and fitted
Flexable
Flexable
'P' clips to hold the air pipe in place
Now I could also have a handle on both sides of the draw bar but I'm happy with this version
The bracket for the draw bar pins, I have no idea what this is for
I quite like milling parts by hand
Some filing to finish and I need a way to mount the piece
Re: 88 parts
Well that's the boggie hard detailing all done, I'm now moving onto the cruciform and gun, I can't really show all that progress on here but you can follow on my Facebook page.
As I add the weld detail, unit markings and weathering ( I like to do all that at the same time ) I will post the results.
It will be for sale once finished, I reckon another two months work, then I'm onto the very rare Bergetiger, Tiger 331 is also for sale, so pm me if your interested.
Thanks go to Phil D and Steve L for the parts they helped me with.
The main pin has the arm rest and that strange bracket bolted in place, this replicated front and back.
Re: 88 parts
The 88 is just about done, just a few days of weathering to do. You guys are going to love your new kits.
Just about everything in this photo is Armortek, I may thicken up those black out convoy white markings.
The lift chains.
The lift chains.
Just about everything in this photo is Armortek.
The very substantial Armortek shield, some like it on, some like it off.
Re: 88 parts
Here's a few more photos to wet your appetite for this superb kit. Thanks also goes to Vince who helped me out with his cad skills.
The Tiger gives you an idea of the  impressive size of the 88
