Zimmerit
Gary Richardson
Has liked: 788 times
Been liked: 1891 times
Re: Zimmerit
Post by Gary Richardson »
Jae-seung Roe wrote:
Fri Jul 15, 2022 2:35 pm
Great hand made Zimmerit tool kit! Did you even make the pattern as well?
Hi Jae-seung Roe
I had a good look at the zimmerit tools Bob lent me and the number of teeth per inch and depth of the Zimmerit/teeth has been documented elsewhere on the forum. The biggest problem was finding a file thin enough and with the correct angle to avoid rounding off the troughs between the teeth. Also make sure the teeth/depths are slightly different so the zimmerit pattern is not perfect.
If you go to my build on the link below you can see how I made them.
viewtopic.php?f=6&t=8881&start=135
Gary
Mike Kasputis
Been liked: 54 times
Re: Zimmerit
Post by Mike Kasputis »
I made my own Zim tool out of brass and plastic.
This is how I figured out the number of teeth.
I measured the side hull at this area and enlarged this picture to 1/6 scale.
In the post on my Tiger Per Sonnervik noted the lines on the front plate in the Zimmerit, here you can see them really well.
Robert Tanzer
Has liked: 1123 times
Been liked: 990 times
Re: Zimmerit
Post by Robert Tanzer »
Thank's for letting me know this Mike K.
