Hello guys
Need some help. I'am working with lower shield. The instructions book does not tell exactly how to put lower shield to front of CNO109.
I have use M3 x 6 button to attach lower shield to the front - 3 qty - is this ok ?
or should I use some others bolt or screw ?
PAK 43 2018 arrived in Denmark
- Been liked: 128 times
Re: PAK 43 2018 arrived in Denmark
- looks this shield ok ?
- pak 43 nr. 20.JPG (78.27 KiB) Viewed 9862 times
- M2.5 nut's hit the back edge of the front
- pak 43 nr. 21.JPG (85.06 KiB) Viewed 9862 times
- Has liked: 5 times
- Been liked: 20 times
Allan, I think I used the Knupfer small head 3mm hex head screws here. With the Armorpax kit , you have to make a larger lower shield that is more accurate, and accommodates the shovel mountings. These smaller screws allowed more swing for the shield as well. The RC scale crawler world has some nice fastener options that help the look as well. I think the bolts on the fixed shield above are those.
Tom
Tom
Hello Tom
thanks for answers and tips/picture.
According to the drawing page 11, it says M2.5 x 5 rnd hd. Maybe I will use your small head 3mm hex head screws instead
Good morning everyone
Now I am 99% finished and have been through all the pages in the manual
There are now some errors that need to be corrected
The shield is loosely attached and the gunsight must be properly attached (have to move shield and other Things)
- shield is loosely attached
- pak 43 nr. 25.JPG (71.1 KiB) Viewed 9755 times
- pak 43 nr. 24.JPG (83.39 KiB) Viewed 9755 times
- pak 43 nr. 23.JPG (84.98 KiB) Viewed 9755 times
- pak 43 nr. 22.JPG (75.11 KiB) Viewed 9755 times
- thank god for the dremel machine. All holes was too small
- pak 43 nr. 26.JPG (86.02 KiB) Viewed 9755 times
- Has liked: 19 times
- Been liked: 160 times
Hello all
First time outside.
First time outside.
- Pak%2043%202%20800x600.JPG (168.07 KiB) Viewed 9112 times
- pak%2043%20800x600.JPG (141.84 KiB) Viewed 9112 times
- Been liked: 19 times
Hello Allan,
what a nice view - the last picture.
Christian
Christian
