PAK 43 2018 arrived in Denmark
Allan Carlsen
Been liked: 128 times
Re: PAK 43 2018 arrived in Denmark
Post by Allan Carlsen »
Hello guys
Need some help. I'am working with lower shield. The instructions book does not tell exactly how to put lower shield to front of CNO109.
I have use M3 x 6 button to attach lower shield to the front - 3 qty - is this ok ?
or should I use some others bolt or screw ?
looks this shield ok ?
pak 43 nr. 20.JPG (78.27 KiB) Viewed 9466 times
M2.5 nut's hit the back edge of the front
pak 43 nr. 21.JPG (85.06 KiB) Viewed 9466 times
Tom Roslund
Has liked: 5 times
Been liked: 20 times
Post by Tom Roslund »
Allan, I think I used the Knupfer small head 3mm hex head screws here. With the Armorpax kit , you have to make a larger lower shield that is more accurate, and accommodates the shovel mountings. These smaller screws allowed more swing for the shield as well. The RC scale crawler world has some nice fastener options that help the look as well. I think the bolts on the fixed shield above are those.
Tom
Allan Carlsen
Hello Tom
thanks for answers and tips/picture.
According to the drawing page 11, it says M2.5 x 5 rnd hd. Maybe I will use your small head 3mm hex head screws instead :D
Allan Carlsen
Good morning everyone
Now I am 99% finished and have been through all the pages in the manual
There are now some errors that need to be corrected
The shield is loosely attached and the gunsight must be properly attached (have to move shield and other Things)
pak 43 nr. 25.JPG (71.1 KiB) Viewed 9359 times
pak 43 nr. 24.JPG (83.39 KiB) Viewed 9359 times
pak 43 nr. 23.JPG (84.98 KiB) Viewed 9359 times
pak 43 nr. 22.JPG (75.11 KiB) Viewed 9359 times
thank god for the dremel machine. All holes was too small
pak 43 nr. 26.JPG (86.02 KiB) Viewed 9359 times
Glen Clark
Has liked: 19 times
Been liked: 160 times
Post by Glen Clark »
It looks so good in bare metal.
Glen.
Allan Carlsen
Hello all
First time outside.
Christian Steinhauer
Been liked: 19 times
Post by Christian Steinhauer »
Hello Allan,
what a nice view - the last picture.
Christian
