Martin's Panzer IV
Martin Hofmann
Has liked: 151 times
Been liked: 1984 times
Re: Martin's Panzer IV
Post by Martin Hofmann »
Now comes a small update with the new front cover of the turret, the ventilation parts of the motor compartment and the back plate with welding lines.
Regards Martin
Robert Tanzer
Has liked: 1118 times
Been liked: 990 times
Post by Robert Tanzer »
Thank you for sharing your excellent work Martin.
Best wishes from Sweden
Robert
Uwe Gerstenmayer
Been liked: 72 times
Post by Uwe Gerstenmayer »
Wie immer ein absoluter Augenschmaus, einfach geniale Arbeit 8)
Gruss vom Uwe :wink:
1:16 Models: Kingtiger
Damon Resch
Has liked: 891 times
Been liked: 81 times
Post by Damon Resch »
Das Gleiche gilt für das, was Uwe gesagt hat. Wie immer schone Arbeit!
Martin Hofmann
Hi Robert, Uwe and Damon,
thank you so much for your nice words.
The next step is to start with the electric and the doors from the turret, but all not ready!
Regards Martin
Martin Hofmann
Here are a small update with the electric installations and the first painted and weathered road wheels from the inner side of the tank.
Regards Martin
Martin Hofmann
The next step was to glue the bearings into the wheels with Loctite 648 and the rubber rings with Loctite 480.
In the middle of the covers i made a sunk hole and glued in a self made grease nipple. They are made from a cap screw M1,6 with a glued ball of 1,5mm diameter into the head and covered with a washer, so you can see the ball from outside.
At the last fotos you can see the layer between the chipping layers before the yellow layer is painted.
Regards Martin
Has liked: 1475 times
Been liked: 1674 times
They look excellent. I didn't know you could even get 1.5mm ball bearings :shock:
Martin Hofmann
Hi Adrian,
thank you so much for the nice words. The balls in the cap screw head are only the balls with dia of 1,5mm and not the whole ball bearing :D :D
But for information : you also can buy bearings with an inner diameter of 1mm!!!! 8) 8)
Regards Martin
Martin Hofmann
After the last chipping layer comes the paint of Dunkelgelb in two variations for the Afrikakorps. Then the chipping process is followed at the road wheels. The sprockets have to come next. Some wheels are only looking primed ( the red ones ), but have also the chipping underground. The wheels with the open bearing is only the spare one for placed at the side of the tank. Now the weathering has to be done.
Regards Martin
Martin Hofmann
The weathering is done. So the road wheels are ready for mounting.
The idler wheels got the medium layer of the chipping process.
Regards Martin
Martin Hofmann
The sprockets are also weathered and all the rubber rings are glued onto the road wheels. Here i had also simulated some fat coming out of the grease nipple a nd the bearings.
Regards Martin
Magnificent Martin, lovely details, regards simon.
John Fitzsimons
Has liked: 6 times
Been liked: 797 times
Post by John Fitzsimons »
Are you using the latest brushless motion pack. I will need to add a motion pack to my Panzer IV soon. I need to get some work done on it.
love your details.
Robert Tanzer
Beautiful work like in a jewelry shop.
I take my hat off for you Martin.
Ps. I am sad to say that i dont will go to Ooverloon this year.
