Chieftain ir detector.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
I am looking for some decent images of the ir detector mounted behind the commander’s coupola, typically I was at the model show at Bovington last weekend and didn’t get a single photo of it.
Has liked: 794 times
Re: Chieftain ir detector.
Charles A Stewart
Has liked: 513 times
Been liked: 933 times
Post by Charles A Stewart »
Hi Steve.
Is this any good:-
Trip hazard 1a.jpg (50.17 KiB) Viewed 3039 times
I can supply dimensions if required.
Cheer
Charles
Steve Norris
Has liked: 8 times
Hi Vincent and Charles.
Thanks for the posts, both are very useful.
There are at least 2 variations of the installation, one as Charles has done and another with the ir detector as per Charles set up but with a longer cable conduit and the armoured shroud further inboard. My plan is to do the second version.
Charles, if you have some dimensions it would be greatly appreciated.
Been liked: 1842 times
Here's a few alternatives, with or without detector (weather protection plug cover in place). Best guess for sizing
What sort of dimensions Charles?
David Battson
Has liked: 124 times
Been liked: 258 times
Post by David Battson »
Hi Vince,
I am interested that you are interested : 8)
Do these help ?
Chieftain was designed in imperial, so I find that most measurements only really start to make sense when rounded to the nearest 1/8 of an inch or so.
