Well, that's never happened before...
Has liked: 1495 times
Been liked: 1699 times
I was doing some maintenance on the Cent BARV and spotted the RH idler was a little loose.
So I removed the hub cap, expecting to have to tighten up the fixing cap.
Nope, still nice and tight.
So I removed the idler completely...
Inner bearing is toast. Some of the ball bearings came out in pieces :shock:
Being at the front, idlers on Centurions are very exposed, so I wonder if this model has suffered a front end collision, which damaged the bearing somehow.
I've ordered new SKF bearings, and will replace all four at the front, just in case.
Klaus Uschkurat
Has liked: 2710 times
Been liked: 11 times
Re: Well, that's never happened before...
Post by Klaus Uschkurat »
hallo,
so ist es wenn man billige Lager einbaut !
Wer billig kauft zahlt doppelt
SKF Lager sind immer eine gute Wahl^ :D
Schönen Tag noch
Gruss Klaus
Chris Hall
Has liked: 536 times
Been liked: 688 times
Post by Chris Hall »
Adrian Harris wrote:
Fri Aug 04, 2023 9:52 am
It did ....... a few years ago at REME. Suddenly it ran amok, and repeatedly rammed into the Scammel display stand until we managed to find the kill switch.
Steve McEvoy
Has liked: 11 times
Been liked: 123 times
Post by Steve McEvoy »
Adrian if everything was still tight l doubt it would be collision damage that caused it. probably just a bearing failure. Seen plenty bearing breakups when l was working on bikes.
Chris Hall wrote:
Fri Aug 04, 2023 11:30 am
That was because Nick walked off with the transmitter and left the tank switched on. Though from memory it was trying to reverse into the Scammel, so that wouldn't have affected the idlers. Maybe I need to check the sprockets as well :roll: :shock:
David Skeldon
Has liked: 33 times
Been liked: 312 times
Post by David Skeldon »
The BARV has been in the sea , so sand and salt may have got into the bearing and over time caused it to deteriorate to the point of failure.
