Mr Dawe's Centurion.
Has liked: 2282 times
Been liked: 7196 times
Re: Mr Dawe's Centurion.
Whilst I wait for the expanding metal I shall get on with the twinkly bits.
That winky pot is great
Parting off very carefully
Polishing the bezels
A small piece of stock used for the headlight bezels
These stock parts are not far off but do need that big bezel
I can't believe the lenses fit perfectly with just a little fetling
Using a needle file to profile the bezels
That's four bezels made, the brackets for those will be tricky
Opening up the winky pot post to take the wires
Turning down the head light post
I want to use the post headlight bowl mounting to keep things nice and strong but incorporate the u channel bracket as well, the post will not really be seen
Moving on with the driving lamps
Not really necessary but I'm going to use red leds for the outer lamps in addition to the ir glass effect
So many tiny pieces
So many tiny pieces
This digital gauge is so useful
Milling of course
Milling of course
A little production line
Angles to match the front plate
Don't get too excited, the lamps are just tacked in place to have a " look see "
This will not be the final position I'm sure, what do you think of the piece of steel for for for the lamp guard surrounds Phil? The diameter is just a gnats tadger under 3 mm.
Winky pot and made a start on the light guards today.
Letting the post into the light body stalk
The correct length
The correct length
Always start with a small drill bit
M4 tap
M4 tap
Those sites are tiny
Now to paint
Now to paint
This will take some head scratching
Measure check, check again , measure and centre pop, I shall make them long and then cut back to finish
I'm being really careful as I only want to make these once
Phil Dawe
Has liked: 757 times
Been liked: 300 times
Post by Phil Dawe »
Huge thanks to Stephen White for his input on the headlights conduit and the winky pot location. :D
The light guards are now well under way
Lights 8-2.JPG (46.29 KiB) Viewed 1187 times
Nice lump!
Nice lump!
I have my own "bend allowance" system that works great for me
Getting the frame pieces all the same takes a little effort, all the hole depths need to be within .5 mm
Tricky and delicate silver soldering
The copper covered welding rod silver solders perfectly
You need a good eye to keep the holes square and plumb
Using the in situ pre drilled holes as a jig you know that the frame fits perfectly and can be removed for further soldering and refitted without any problems, if the rod and or holes are out of plumb removal can be very difficult.
All soldered cleaned up and primed
Note how much paint there is on the light guards , remove those layers of paint and our stock rod needs to be  1 mm less in scale in diameter
Lights 8-2.JPG (46.29 KiB) Viewed 1116 times
This piece of mild steel is for the tiny brackets x4 that are welded to the frame uprights
Not sure what these brackets were for.
And now onto the bezel fittings to include the awkward brackets, the conduit fittings are on back order from DD, well not really back order as soon as Dave gets a chance to cast them. A question for Dave, what diameter rod will I need for the conduit to fit your fittings please?
Change of plan regarding the led wires.
Led secret wiring
Led secret wiring
Dissolving the cyno so I can reroute the led wires
I've decided that the led wires must be hidden so the conduit looks perfectly convincing
Yet another angle to work out
Extension mounting tubes not only to support the headlamp but to carry the cables into the hull.
Lines for reference just in case I make a cockup
A bit of of a pyramid but it works well
Centering is always a chore but it has to be done
Just following the invisible numbers
Darn awkward work but very rewarding
All perfectly machined ready for the brackets
Although the metal looks like it's off cuts it is in fact the beginning of some tiny brackets
16 of everything to make
Bryan Brown
Has liked: 403 times
Been liked: 9 times
Post by Bryan Brown »
How do you make time for food drink and sleep considering the progress you make each day on various models
Bryan :wink: :wink:
Well Bryan as you have asked, you wouldn't believe how much I have to do on a daily basis, I love the model building work as I suppose it's an escape from it all!
We have , I say we, me and the wife ( we live separately ) look after our own land here in Cornwall, I then also look after another 100 acres or so of pasture and woodland. We have 8 horses, 4 cats, 2 dogs, 1 sheep and a few bees.
Time is precious for sure, I have my own business, I do my own cooking and house work all with a degenerative back disease but morphine helps! I shall keep going until I can't. I have given up riding motorcycles and showing cars though, Phil.
Chang
Has liked: 16568 times
Been liked: 487 times
Post by Chang »
Phil Woollard wrote:
Tue May 23, 2023 7:32 am
....Time is precious for sure, ...
Phil your space-time continuum must be in such high speed that the Einstein's General Theory of Relativity applied, ie, the "Time Dilation" effect occurred. :shock:
If that can make you feel dizzy then I agree Chang :wink:
Making tiny parts for those headlamps
There's always a scrap piece of metal that works kicking around somewhere
These ears are to big just now but that's all planned.
This all needs to be functional so in the future if an led needs replacing you can remove the bezel .
I need to reduce these fittings down by about 20% but that will be done once it's all in place, the parts are very fiddly indeed,  so best fix then file
I decided to finish one lamp completely, really just to prove the concept.
Pin drills
Pin drills
The resin conduit arrived today, these Dave has sent for patterns prior to the metal variety which will follow
I'm happy with the result
My smallest tap
My smallest tap
Anyone know which way up these light lenses go, more open part to the top or to the bottom?
That is a lot of work!
My kindle camera is getting a bit old now
Phil Dawe
Post by Phil Dawe »
Beautiful, Huge thanks to Didier Molard who sourced the basic headlamps for us and Phil W's work which never disappoints! :)
Nearly ready for paint.
Tiny screws, leds and some paint. Then mount and wire in to drivers compartment switch panel .
