Per
After I finished the fan cover I thought it was too thick, now that I know the thickness I will fix it, Thanks. Do you have a picture showing the screw in the middle, from all the pictures I have seen I cannot see a screw.
You are right about not being able to see the zimmerit on the plate, I thought that it was not applied there since I could not see it. I guess that not alot of people see it because if you look at all the models built of the Tiger (all scales) very few have applied the zimmerit there. Good point about there only being one factory applying the zimmerit.
That picture from Tigers in combat I is that from the hard cover version, I have the soft cover and it is not in there, what page is it on.
Brian
I used .015" brass for the front, rear and side fenders.
Here is a picture showing the parts to make the front fender. I made my own hinges also.
Here is a comparison of my fender to the original one. The original did not come forward enough.
[/img]
I also made my own functional jack brackets. compared to original.
[/img]
Here are the parts to make the jack brackets.
[/img]
