M26 Pershing Production Images
Been liked: 1842 times
Re: M26 Pershing Production Images
Sorry Jerry,
I was referring to the crew in the M3A1 or the M4A1 prototypes or earlies not the Nicaraguan Contras.
:lol:
Been liked: 3699 times
Prototype M26 Pershing turrets arrived on Friday - very happy how these have turned out. I placed a flip board marker next to the turret to show the scale.
The interior of the turret has been cast hollow so it "only" weights 11kg - within 150 grams of the predicted weight from our 3d modelling software.
We will get these onto our CNC machines in the next few days to machine all the features needed.
Mike Conley
Has liked: 224 times
Been liked: 181 times
Post by Mike Conley »
Great castings!!! I would LOVE to see more videos of the final machining on the turret, mantlet, and cast parts!!
Damon Resch
Has liked: 908 times
Been liked: 82 times
Post by Damon Resch »
Ditto!
A rendering of the exhaust and barrel travel lock assembly as well as a couple of pictures of the exhaust.
Pershing Barrel travel lock and exhaust.JPG (36.18 KiB) Viewed 4467 times
Sample pressed steel wheels and rubber tyres showed up today.
Very pleased with how these have turned out.
Mike Conley
WOW AGAIN!! :D
Chang
Has liked: 16559 times
Been liked: 487 times
Post by Chang »
A very detailed wheel indeed.
Unlike German design , no locking tabs used to prevent the nuts from being loosen.
Is German too dedicated , or American don't think it is necessary? What is the true reason behind using it or not?
Regards,
Lerh Chang
Has liked: 1484 times
Been liked: 1687 times
Possibly the next size up for the fasteners ?
Chang
Post by Chang »
Was the flange nut used? or dome washer? inner lock washer? conical washer?
Maybe nothing but a nut.
Looks like the flange is part of the bolt.
The exhaust looks like a tricky piece of machining. It's not easy to tell from the angle but does are the vents cylindrical or conical ?
Roadwheel on the Pershing tracks.
Right hand hull side1
Right hand suspension bogies - positions 2,3,4,5
Front casting.
Front casting.
Right hand filler cap located behind turret
Rear deck T piece.
Rear deck T piece.
Left hand side return roller
Left hand side position 2 suspension bogie.
Damon Resch
Wow, this tank is looking great! Even though I’ve missed out on German armor in the past,(King Tiger) for my first Armortek tank, I’m thrilled about buying a M26 Pershing.
