Florian StuG build
- Has liked: 1381 times
- Been liked: 1578 times
Re: Florian StuG build
I've seen magnets used before but not such an engineered solution.
What he hasn't realised is that it will now only drive North and South
- Has liked: 293 times
- Been liked: 639 times
Hopefull the right technical solution Adrian. - Maybe the StuG is now running faster to north or south
This magnets are verry smal, so I did some more to suck firmly tight enough.
cheers
Florian
cheers
Florian
- Has liked: 465 times
- Been liked: 405 times
Another great build , I really like the sand blasting technic
Kind regards from Björn
Thx Björn,
the sand blast is first to hold welding and paint work tight. Secound for the rough opting in the finishing. It is a test for me to look how it works in the end with the weathering.
Well the best thing you can do is buy the kit first, and start to build last, if you're a newbe.
On my Famo build I was the secound starter. Sometimes not so easy, but helpfull in this forum.
Like to see your build soon
Yes I think you´r on the spot there for a better paint work !florian rudolf wrote: ↑Wed Apr 14, 2021 5:34 pmThx Björn,
I also like you´r great detail work .
Thank you Björn,
in time I'm on the first paint work on the chassis. So not spectacular at all, because only the base.
Looking forward to do some more soon. - Normaly its now time for one of my other hobby, unfortunatly the f... C-19 canceled lots of meetings and events.
I'm not sleeping...
Having not much time this summer to build, but doing some work on the StuG details and finished the track wheels.
today I set 240 rivets for the fenders... feel like setting 500
- Has liked: 2263 times
- Been liked: 7149 times
Nice!
Thanks Phil,
today it was a rainy sunday, so time to do same more on the StuG...
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
That was some great details Florian ,
Didn´t know that you could solder brass on steel
You have to share you´r technic
I also like the with what I think is "bullet hitting the mg shield "
Hi Björn,
its pretty easy.
Heat the steel with a hot flame, then solder the brass with solder.
You are correct with the MG bullet simulation
its pretty easy.
Its going on.
Fortunatly the engines are installed, so I could fix the mid section an the track fenders. - With this I could paint the first color. Any more will be paint soon, after fixing some more details.
The tracks are running verry well. can't wait to see it running in terain Cheers
Florian
Florian
