Florian StuG build
florian rudolf
Has liked: 297 times
Been liked: 645 times
Florian StuG build
Post by florian rudolf »
Now I'll start my new building block of my secound StuG from Armotek.
First building pictures comming soon :D
florian rudolf
Re: Florian StuG build
StuG meets Famo
Start building
florian rudolf
Today it is going on at hull, gear, and wheels...
Had some trubble with my driven gear, like I read it allready, so I had something to drill.
florian rudolf
It looks realy smal next to the Famo :shock:
But fortunatly there are many parts comming soon to make the StuG bigger.
Roy Beukeveld
Has liked: 171 times
Been liked: 118 times
Post by Roy Beukeveld »
Hi Florian, good luck on your new StuG build!
I’m looking forward to seeing your progress and accomplishments.
Btw, the size comparison with the Famo is impressive :shock:
Kind regards,
Roy
florian rudolf
Thank you Roy,
well I don't want to bore you guys, because here are many threads about the StuG. I'll post all I make diffrent way to the kit.
Now I still working at the normal hull stuff. the welging is comming soon.
Some hull parts I plan to take in my sand blast cabine.
Florian
florian rudolf
Did some work this weekend...
1. I had to drill down the inner roadwheels, because the chain teeth are a little too thick...
Last edited by florian rudolf on Fri Mar 12, 2021 11:20 am, edited 1 time in total.
florian rudolf
2. I blasted different parts. This is used for the later look
florian rudolf
Last but not least I started to make the the suspension.
Finish for today. It lokks like a tank now :)
florian rudolf
Last time I did some work on the track wheels.
I drilled the sleeves for a bit better looking scale look out.
Big brother is whatching grow up
florian rudolf
Did some wellding today.
florian rudolf
Its wellding day halleluja.....
I did nearly all wellding work today. Next thing is the primer paint and begining to do more detailing
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Well done :D
cheers
Steen
florian rudolf
Hi all,
today I did something an the upper hull top roof.
I'll fix it with neo dyn magnets (5mm x 2mm). I pressed the magnets into the 3mm hull plate, where the metal holders for the cover is. Than I glue ftom the top side with 2k alu metal glue. I need 24 magnets. It fix it perfectly and strong enouth.
Forther I did some model M3 screws for scale look.
Also optimized the wellding on the track wheels.
Florian
Christoffer Ahlfors
Has liked: 748 times
Been liked: 360 times
Post by Christoffer Ahlfors »
Wow!
That's a lot of magnets!
Interesting concept! :D
