Tank jacks
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Tank jacks
Hi guys,
Maybe a strange question, but I'm wondering how were jacks actually used with tanks?
I see lots of WW2 tanks driving around with a jack on top.
But how were they actually used? What and how would you lift with them? Ten tons, twenty tons, on a single small foot.
Does anybody have any photos of a ww2 tank with such a jack in place?
Kind regards,
Roy
Roy
- Marco Peter
- Has liked: 1530 times
- Been liked: 797 times
Re: Tank jacks
I do not have the answer, but some very interesting photos come to mind - google 'maus tank jack'
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
- Has liked: 8 times
- Been liked: 701 times
Re: Tank jacks
Hi Roy
Most tanks (German at least) carried a jacking block, this was basically a large wooden block as the name suggests, used to spread the load of the jack. It’s worth noting that the jack would not normally be used to lift the whole tank, just a corner.
Hope this is helpful
- Has liked: 1038 times
Re: Tank jacks
The main use for a jack is to lift a road wheel axle in order to change the wheel. It also has a role in track maintenance.
- Been liked: 83 times
- Has liked: 1481 times
- Been liked: 1687 times
Re: Tank jacks
Then he realises that that's the wheel he has to take off
- Roy Beukeveld
Re: Tank jacks
Hi Steve, I see, lifting a corner seems do-able considering the capacity of some jacks. But when doing so was there a surtain provision on the hull for the jack to engage with? I mean, tanks have a small floor clearance, these jacks don't fit underneath so there must be something for it?Steve Norris wrote: ↑Mon Oct 05, 2020 10:29 pmHi Roy
Hi Stephan, lifting a road wheel axle makes sense to me, but it must have been used fairly flat orientated then? Any ideas how they managed practically speaking?Stephen White wrote: ↑Mon Oct 05, 2020 11:27 pmThe main use for a jack is to lift a road wheel axle in order to change the wheel. It also has a role in track maintenance.
Hi Manny, nice picture! Thx! but like Adrian noticed, either he doesn't know what he is doing or he is trying to achieve something other than exchanging a road wheel...
Hi Marco, interesting photos indeed, one of them seems to show some kind of bracket on the hull onto which the jack adapts.Marco Peter wrote: ↑Mon Oct 05, 2020 9:49 pmI do not have the answer, but some very interesting photos come to mind - google 'maus tank jack'.
Kind regards,
Roy
Roy
- Kees van Rijswijk
- Has liked: 353 times
- Been liked: 161 times
Re: Tank jacks
Hi Roy,
Not easy to find foto,s on using the Jack. Believe the where used to lift the road wheels for maintenance. As you can see in the foto. The front road wheel is lifted to its up position to the bumpstop. To release the sprocket.
- Kees van Rijswijk
Re: Tank jacks
Another interesting foto of using a jack on a tiger !
- Tiger Jack.jpg (83.84 KiB) Viewed 1710 times
Re: Tank jacks
I think anyone with a copy of Tigerfibel
Can show us how to properly deploy the jack,
- Roy Beukeveld
Re: Tank jacks
Hi Kees, that's an interesting picture indeed. Seems to be a surprising position to place a jack. At first glance it looks like its pushing against the mudguard but it's the superstructure on that point already...Kees van Rijswijk wrote: ↑Tue Oct 06, 2020 7:41 pmAnother interesting foto of using a jack on a tiger !
Hi Manny, that's a good photo too, looks like they used the towing eye to attach the jack...
Yes indeed, a good case of RTFMManny Leung wrote: ↑Tue Oct 06, 2020 8:07 pmI think anyone with a copy of Tigerfibel
Can show us how to properly deploy the jack,![]()
Kind regards,
Roy
Roy
- Has liked: 6 times
- Been liked: 194 times
Re: Tank jacks
Hi all,
Here are some nice ”jack in action” pics, enjoy.
It´s all in the details!
- Been liked: 1842 times
Re: Tank jacks
Excellent pictures Kent, especially like the one in the manual that depicts the use of a special fitting on the hub to lift the road wheel.
Then in the "field" the jack goes straight under wheel rim.
Operators
Operators
- Has liked: 257 times
- Been liked: 147 times
