Florians FAMO build
- Has liked: 297 times
- Been liked: 645 times
Re: Florians FAMO build
Did some paintwork today.
It looks diffrent to other tank paints, but its frm al real Famo. With some weathering I think its looking good
Last edited by florian rudolf on Sat Jan 09, 2021 8:05 am, edited 1 time in total.
- Has liked: 7 times
- Been liked: 46 times
Thank you Simon,
I did'nt realy know if it looks good or not. It's verry special, but verry rare indeed.
- Marco Peter
- Has liked: 1538 times
- Been liked: 798 times
I have to get used to it, weathering will really make it shine. But what I really like is how well you replicated it, skills!
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
- Been liked: 17 times
Oh my god Florian, I had the shock of my life when I seen this, it looked like Chinese graffiti !!!, HOWEVER - I think if you blend it in a bit it could be a really good look, sorry don't mean to offend but its better to be honest
Good morning Adrian,
i thought the same when i was done.
Well, the first camouflage is not finished. weathering follows soon.
Lets have a look how its shows if finish.
- Chang
- Has liked: 16582 times
- Been liked: 487 times
Good'y Florian,
Far behind your building progress, I read this thread almost everyday for good ideas. Today I just need to ask for your opinion.
On your 28 Jan 2019 photo, the linear actuator (CP0314) for steering shown a longer white rod (see the red arrows) : When I try do the same thing, found the white area shown on my linear actuator is very short. So short that it can't link with the steering arm. Did I do it wrongly, or missing something? I have tried to pull the white rod outward, but just failed.
Do I need to do so by bench testing, ie, by connecting the battery, and connect R/C Tx, Rx, and the Motion Module? If no, what else should I do?
With regards,
Lerh Chang
With regards,
Lerh Chang
- Heiko Sattler
- Been liked: 535 times
- Been liked: 3705 times
The actuator in your picture is completely retracted - this would be its position when the wheels are turning right. If you connect it to power it should centre (extend to its mid point).Chang wrote: ↑Thu Jun 11, 2020 4:56 amWhen I try do the same thing, found the white area shown on my linear actuator is very short. So short that it can't link with the steering arm.
Do not force the white rod by hand - this will damage the actuator.
Kian
Danke für dein Lob Heiko. Das von dir, ehrt mich.
Kian is on the right way. Don`t try to pull or turn on the liear servo.
You have to connect the servo wiht the steering from the axle. Maybe the Wheel is not strait in front. - If this, you have to adjust it on your controler.
- Heiko Sattler
Definitiv
Wenn du nach Overlooon kommst kannst du sie ja mitbringen.
Alternativ habe ich ja noch meine PAK43/41
Mit deiner 88 is das Gespann dann ja locker 4m oder?
Mit meiner PAK komm ich auf Gespannlänge von gut 3m
Last edited by florian rudolf on Fri Jun 12, 2020 10:57 am, edited 1 time in total.
Just now I working on the Famo seats. I like the style from Phil's Famo seats. - Thats my reference
I start weathering my Famo, because I am waiting for some stuff for my seats...
