Tiger build
mark j. radick
Has liked: 394 times
Been liked: 538 times
Re: Tiger build
Post by mark j. radick »
Robert Tanzer wrote:
Tue Mar 10, 2020 6:21 pm
Hello
Where did you get the high pressure regulator that attaches to the co2 cylinder?
Robert
Hi Robert....I bought it off Amazon
Phil Markham
Been liked: 22 times
Re: Tiger build
Post by Phil Markham »
Hi Mark,
Really enjoying your build. My Tiger is of the same batch run as yours, 2nd run, early Tiger variant with Feifel filters. My turret is stamped with number 2. I;ve been building it on and off now for the last 15 years! More off than on I hasten to add :wink:
mark j. radick
Re: Tiger build
Not sure what they are or their purpose ...they look like rivets..I added them anyway
mark j. radick
Re: Tiger build
Finished detail work...I will add wiring once painted...tomorrow will install to turret
Has liked: 1481 times
Been liked: 1687 times
Re: Tiger build
The rivets look like hold on a mounting point for the end of the chain which attaches to the plug at the back of the firing tube.
I would guess the plug was detached whilst the canisters are loaded, so that there is no chance of one going off as it was being loaded. If you were stood behind when plugging them back in, it might still be a shock but not ruin your day quite so much.
Smoke Discharger Close Up.jpg (151.61 KiB) Viewed 14085 times
mark j. radick
Re: Tiger build
Adrian Harris wrote:
Wed Mar 11, 2020 11:09 pm
Thanks Adrian :D
mark j. radick
Re: Tiger build
Reworked the back end of the smoke dischargers after looking at Adrians awesome photo...closer to scale now
Has liked: 161 times
Been liked: 830 times
Re: Tiger build
Beautiful parts Mark, your tiger is awesome. Love the recoil and blank fire.
B
mark j. radick
Re: Tiger build
Reworked for a few more hrs then installed smoke launchers and escape hatch
mark j. radick
Re: Tiger build
Cut shallow recess surrounding loaders hatch and started work on hatch and vent
mark j. radick
Re: Tiger build
Adhering the handle to the vent did not appeal to me as there is very little surface area....so I soldered it...most "white metals " can be soldered but you need much experience as it is temperature critical and easy to destroy the piece...no need to add simulated weld now :wink:
Marco Peter
Has liked: 1530 times
Been liked: 797 times
Re: Tiger build
Post by Marco Peter »
As real as it gets!
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Robert Tanzer
Has liked: 1121 times
Been liked: 990 times
Re: Tiger build
Post by Robert Tanzer »
Looks Fantastic
mark j. radick
Re: Tiger build
Cupola and stowage bin to do...looking for a "Vince Abbot" cupola to buy...if not I'll be scratch building one
Re: Tiger build
Armortek might have the basic parts from the Tiger 131 release, plus Field of Armor stock Mike Stannard's upgrade parts for it.
