Hi Robert....I bought it off AmazonRobert Tanzer wrote: ↑Tue Mar 10, 2020 6:21 pmHello
Where did you get the high pressure regulator that attaches to the co2 cylinder?
Robert
Tiger build
- mark j. radick
- Has liked: 394 times
- Been liked: 538 times
Re: Tiger build
- Been liked: 22 times
Re: Tiger build
Hi Mark,
Really enjoying your build. My Tiger is of the same batch run as yours, 2nd run, early Tiger variant with Feifel filters. My turret is stamped with number 2. I;ve been building it on and off now for the last 15 years! More off than on I hasten to add
- mark j. radick
Re: Tiger build
Not sure what they are or their purpose ...they look like rivets..I added them anyway
- mark j. radick
Re: Tiger build
Finished detail work...I will add wiring once painted...tomorrow will install to turret
- Has liked: 1492 times
- Been liked: 1699 times
Re: Tiger build
The rivets look like hold on a mounting point for the end of the chain which attaches to the plug at the back of the firing tube.
I would guess the plug was detached whilst the canisters are loaded, so that there is no chance of one going off as it was being loaded. If you were stood behind when plugging them back in, it might still be a shock but not ruin your day quite so much.
- mark j. radick
Re: Tiger build
Thanks AdrianAdrian Harris wrote: ↑Wed Mar 11, 2020 11:09 pmThe rivets look like hold on a mounting point for the end of the chain which attaches to the plug at the back of the firing tube.
- mark j. radick
Re: Tiger build
Reworked the back end of the smoke dischargers after looking at Adrians awesome photo...closer to scale now
- Has liked: 165 times
- Been liked: 849 times
Re: Tiger build
Beautiful parts Mark, your tiger is awesome. Love the recoil and blank fire.
B
B
- mark j. radick
- mark j. radick
- mark j. radick
Re: Tiger build
Adhering the handle to the vent did not appeal to me as there is very little surface area....so I soldered it...most "white metals " can be soldered but you need much experience as it is temperature critical and easy to destroy the piece...no need to add simulated weld now
- Marco Peter
- Has liked: 1539 times
- Been liked: 798 times
- Has liked: 1131 times
- Been liked: 990 times
- mark j. radick
Re: Tiger build
Cupola and stowage bin to do...looking for a "Vince Abbot" cupola to buy...if not I'll be scratch building one
Re: Tiger build
Armortek might have the basic parts from the Tiger 131 release, plus Field of Armor stock Mike Stannard's upgrade parts for it.
