Tiger build
mark j. radick
Has liked: 394 times
Been liked: 538 times
Re: Tiger build
Post by mark j. radick »
Took a short break...started working on grills and engine hatch..little details 1st...made armored fuel cap covers and engine hatch locks..
mark j. radick
Re: Tiger build
Decided to machine down supplied square head bolts to help recess as much as possible...was able to shave 3/64 off....cutting down on the shoulder and the head......every little bit helps
Has liked: 794 times
Re: Tiger build
That's a great idea to make those brass engine hatch locks in two pieces.
Has liked: 1040 times
Re: Tiger build
Mark, this is a quality build, a great pleasure to follow.
mark j. radick
Re: Tiger build
Progress had been slow and sporadic due to a bad shoulder (rotator cuff tear)... some pics of rear deck details
20191119_203021 (2).jpg (95.09 KiB) Viewed 2491 times
Re: Tiger build
excellent, regards simon manning.
mark j. radick
Re: Tiger build
Reworked welds around armored fuel caps...much closer to scale now
mark j. radick
Re: Tiger build
Textured white metal castings and snorkel base cap by stippling to look more like cast..filled in back of center casting
mark j. radick
Re: Tiger build
Started engine deck grate screens using .030 stainless steel hard soldered
Last edited by mark j. radick on Sun Nov 24, 2019 12:56 pm, edited 1 time in total.
Re: Tiger build
How did you paint the tow cables?
mark j. radick
Re: Tiger build
Vince Cutajar wrote:
Sat Nov 23, 2019 8:33 pm
Hi Vince...my cables are fabricated out of stainless steel...I used a product from Caswell called stainless steel blackener... simply brush on or dip..wait a few moments then rinse off...I then give it a quick rub with an abrasive pad to highlight
Re: Tiger build
Thanks for the info Mark.
mark j. radick
Re: Tiger build
Made up engine grate screen covers out of stainless....
mark j. radick
Re: Tiger build
Before and after using blackening treatment
Has liked: 165 times
Been liked: 849 times
Re: Tiger build
Beautiful details Mark. A joy to follow! Simply amazing work.
