Tiger build
- mark j. radick
- Has liked: 394 times
- Been liked: 538 times
Re: Tiger build
Took a short break...started working on grills and engine hatch..little details 1st...made armored fuel cap covers and engine hatch locks..
- mark j. radick
Re: Tiger build
Decided to machine down supplied square head bolts to help recess as much as possible...was able to shave 3/64 off....cutting down on the shoulder and the head......every little bit helps
- Has liked: 794 times
- Has liked: 1040 times
- mark j. radick
Re: Tiger build
Progress had been slow and sporadic due to a bad shoulder (rotator cuff tear)... some pics of rear deck details
- 20191119_203021 (2).jpg (95.09 KiB) Viewed 2483 times
- 20191119_203541.jpg (89.39 KiB) Viewed 2483 times
- 20191119_202945.jpg (77.57 KiB) Viewed 2483 times
- 20191119_203834.jpg (112.6 KiB) Viewed 2483 times
- 20191119_202917.jpg (74.88 KiB) Viewed 2483 times
- 20191119_203240.jpg (78.6 KiB) Viewed 2483 times
- Been liked: 1767 times
- mark j. radick
- mark j. radick
Re: Tiger build
Textured white metal castings and snorkel base cap by stippling to look more like cast..filled in back of center casting
- mark j. radick
Re: Tiger build
Started engine deck grate screens using .030 stainless steel hard soldered
Last edited by mark j. radick on Sun Nov 24, 2019 12:56 pm, edited 1 time in total.
- mark j. radick
Re: Tiger build
Hi Vince...my cables are fabricated out of stainless steel...I used a product from Caswell called stainless steel blackener... simply brush on or dip..wait a few moments then rinse off...I then give it a quick rub with an abrasive pad to highlight
- mark j. radick
- mark j. radick
- Has liked: 165 times
- Been liked: 849 times
