Tiger part #
- mark j. radick
- Has liked: 394 times
- Been liked: 538 times
Tiger part #
Hi ! would anyone happen to have the part number for the one piece brass turret ring for what I believe was on the 2nd generation tiger kit ?
- Has liked: 1484 times
- Been liked: 1692 times
Re: Tiger part #
On the 2010 Mid Tiger and 2012 Late Tiger, the turret bearing part number was CE0490.
- mark j. radick
Re: Tiger part #
No ball bearings then, just a brass ring around the hole in the top of the hull.
If you can, I would seriously recommend following Steve Stuarts mods to fit a lazy susan bearing instead. I'm going to be doing that to a 205 Mid Tiger sometime soon. It makes such a difference, especially to a tank with as heavy a turret as the Tiger.
- Been liked: 33 times
Re: Tiger part #
I would be interested in doing that turret ring mod to my tiger which is a 2 piece ring. I am hoping you will be doing lots of photos and part numbers as to where we can buy the bits. great idea for an upgrade kit ???
Regards Andy Q
Jersey Channel Islands
- Been liked: 315 times
Re: Tiger part #
Hi Adrian, Andy
Here is a quick look at what I did a few years ago, the bearing is off ebay, router and a block of wood to steady it small cuts (the casting is very soft), cad off to the laser cutter for a new main gear and spacer, a few holes and 2 clips to hold the turret on. I also put smaller ball between each of the standard ball to stop the pinching that was happening then a little graphite powder and it is good to go. Pm me if you would like the dxf file for the laser cutting?
Liam
Liam
- Been liked: 735 times
Re: Tiger part #
I wanted to ask the "friends" of the forum, if they can tell me if Armortek has an upgrade kit to install a tiger turret rotation pad. Mine is a Mid 2010. I have already asked Armortek twice, but have I had no answer? !! Many thanks to all.
- Has liked: 792 times
Re: Tiger part #
Hi Ivano
It seems that there is no official upgrade kit but you still can get the parts separately. Did you see this thread?
viewtopic.php?f=6&t=7536
Re: Tiger part #
Hi Vince,
yes, I have seen this topic, but I must confess that it is not clear to me how the work was done. Unfortunately with the translator everything becomes very difficult. I searched on the Internet for a rotating crown (bearing) with the inner diameter equal to the diameter of my turret (28 cm). But I found only 25, 30 or 35 cm. Perhaps the new tower has other diameters ?? !! Thank you
Re: Tiger part #
Ivano
I measured my bearing and it has an outside diameter of about 350mm and an inside diameter of about 300mm. Something like this:
https://www.ebay.co.uk/itm/Aluminium-La ... 01m_Vffa-A
The hull roof hole diameter is about 325mm so it seems to be bigger than yours.
Try and get in contact again with Armortek to see what they say. Sometimes when they are busy they may take some time to respond.
In bocca al lupo
In bocca al lupo
Re: Tiger part #
I will try to write again to Armortek, maybe this time they will answer me. Anyway many thanks for the information. Ivano
- Has liked: 2532 times
- Been liked: 96 times
Re: Tiger part #
Hi Vince,
Armortek answered. Currently there are no spare parts available for the tiger1. I will have to invent something simple, if possible, having reproduced the inside of the turret, I must respect the general dimensions of the Armortek 2010 design.
Anyway thanks
Anyway thanks
