- Has liked: 166 times
- Been liked: 849 times
Cool Brian
Mine will be from Sch. Pz Abt 102! Looking good!
- Has liked: 794 times
- Brian Ostlind
- Has liked: 976 times
- Been liked: 2068 times
- Has liked: 1495 times
- Been liked: 1699 times
> All the artworks have unpainted ROADWHEELS
It's my understanding that the road wheels were either left all in the base colour, or painted completely in one of the camouflage colours, as a rotating wheel with striped camo on it shows up much more more readily than one which is a single colour.
- Has liked: 1040 times
Spot on Adrian. There is specific mention in the various Heer Tarnanstriche instructions of the need to keep rotating parts in a single colour in order to avoid creating a stroboscopic effect which would compromise the camouflage. That principle is pretty common amongst AFV operators.
You have to disregard contemporary colour schemes seen on museum vehicles because they’re so often inaccurate. The Tank Museum King Tiger is a classic example. It has camouflage extending onto the road wheels. Wrong.
There is another consideration. German wartime AFVs were supplied from the factory in a single base colour. Camouflage was applied at unit level. Tanks crews by and large follow Zipf’s principle of minimum effort. Why bother applying camouflage to the running gear when it will immediately be covered in dirt and when the vehicle will generally be hull down to the enemy in static positions?
That said, you can find exceptions, especially when a vehicle has been tarted up for inspection in barracks.
No camouflage on road wheels (just like no rust on tracks.......)
- Has liked: 6 times
- Been liked: 194 times
Hi Brian,
I agree with Stephen and Adrian, painted roadwheels will stick out when running the tank.
But at this Late Tiger1 period of the war it was up to each unit to decide what paint sceme to be used and painted road wheel on Tiger1 did exist.
However on SS101 2:nd company 2:nd zug they was plain Dunkelgelbe but with the always seen grease stains.
Here are some photos of that company in Paris on their road march to Normandy
- image.jpeg (79.56 KiB) Viewed 2076 times
- image.jpeg (71.94 KiB) Viewed 2076 times
- image.jpeg (62.95 KiB) Viewed 2076 times
It´s all in the details!
- Brian Ostlind
WALL-E
(Sorry, spent most of today out in the sun
Those sprockets look great.
I'd say those look good too! Although the resemblance to WALEE is there as Adrian pointed out - the grime level looks good! The model will add its own weathering as you drive it.
- Brian Ostlind
IDLER: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
I simplified my weathering process and got a better result.
- Brian Ostlind
TEXTURE???
Where does it belong and where does it not belong? Is there a list? I want to do the top of the hull and turret is that some sandy texture?
Not sure how relevant it is to a Late Tiger but the top of the turret of 131 at Bovington is as smooth as a baby's behind.
- Brian Ostlind
SPROCKETS: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Weathering finishing touches with European Dust and Carbon Black pigments.
Dramatic lighting...
- Brian Ostlind
