Tiger1 Firing Trials By Magpiespyro
Has liked: 2282 times
Been liked: 7196 times
This video shows some of the firing trials that we conducted using the Armortek Tiger1 which led to the manufacture of the 12g firing device.
The second Tiger 1 firing has never been shown before as a video.
ATTILA KISS
Has liked: 13 times
Been liked: 4 times
Re: Tiger1 Firing Trials By Magpiespyro
Post by ATTILA KISS »
Intersting, HD ??
Attila
Na before HD Attila regards Phil.
Gerhard Michel
Has liked: 3 times
Been liked: 691 times
Post by Gerhard Michel »
Wow, very nice feature, but may I say that I miss a little recoil.......?
In my tanks I implemented that recoil, but here I miss exactly your kind of muzzle fire :twisted:
Gerhard
Yes recoil ! That's a can of worms. Mechanical recoil with a flash is easy, you can get all that from Armortek but sadly the 12 gauge firing device no longer, but there are still many out there being used, we as in Magpiespyro have of course one or two.
You need hydraulic recoil for realism with return springs to dissipate the force and so return the cannon, the vehicles mass/suspension soaks up a high percentage also, that too is replicated mechanically with motor kick and looks very cool.
We have conducted many experiments with cannon charges even sending the 88mm barrel down range after using an over size load causing metal components to fail, it was found 50 mtrs away.
Also mixing the mechanical/igniferous methods but the timing is tricky! E=MC2 and stripped threads and all that.
We will endeavour to post a film of a system that I have been working on at some point but for now I will use editing trickery to achieve the desired effect, regards festive Phil.
Genuine Tiger1 firing looks so cool.
Gerhard Michel
Has liked: 3 times
Well, I know the problems having to move a heavy firing unit with fast recoil. Perhaps you should fire a real bullet; then the recoil comes from alone.........? :twisted:
Here in Germany we don't have any problems with pyrotechnics in toys! Only a gentle try in that direction would cause a middle firestorm in the authorities; therefore we hold our fingers away! Our friends in Switzerland however may even use armed weapons in model tanks, as far as I know....... :mrgreen:
Gerhard
Like this? :o Photo removed :)
Been going through my old videos and found a few pics that may be of interest. Just enjoy don't try this at home :D
The T1 has been rebuilt many times thanks to Armorteks spares service.
Tiger1,Anti tank rifle at a Tiger1 hulk.-mz7Rk4NgISI_x264_Moment(4).jpg (50.35 KiB) Viewed 3106 times
The very moment a Tiger 2 runs over a mine breaking a track link.
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
very impressive Phil :-)
cheers
Steen
Cheers Steen, here's the next in sequence in the Tiger 2 mine explosion.
Not a huge charge but enough to fracture track links
The chances are the crew would have carried on forward after the mine strike, the track would have separated and run off the sprocket rendering the vehicle immobile.
