Comet No 34
Steve Stuart
Has liked: 264 times
Been liked: 196 times
Re: Comet No 34
Post by Steve Stuart »
Stephen White spotted the cover plate lurking, nearly hidden, ready to cause angst. I have chosen this picture to be my prototype, it has a simpler profile to reproduce.
Prototype
Prototype
These are the finished items fitted in place, so the side plates are now nearly done, waiting to be installed.
Model
Model
So time to clean up, tidy up, and get the Red Oxide out!
Peter Curran
Been liked: 15 times
Re: Comet No 34
Post by Peter Curran »
Such awesome detail
Steve Stuart
Re: Comet No 34
It is peculiar how a detail that you have never noticed before suddenly becomes apparent. The Comet at Tank Fest made it so obvious and I cannot avoid it.
Comet at Tank Fest
Comet at Tank Fest
This is how I have replicated these plates with their counter sunk bolts
Model Gear Cases
Model Gear Cases
This was done by skimming the edges to replicate what I can see on the Tank
I am now waiting for a delivery of bolts from Knupfer so as to start bolting things together, hopefully early next week!
Paul Wills
Has liked: 646 times
Been liked: 143 times
Re: Comet No 34
Post by Paul Wills »
Highlighted by the mud I would say :wink:
Paul.
Steve Stuart
Re: Comet No 34
Mud has its uses, the slotted bolts would otherwise have been hard to spot!
Steve Stuart
Re: Comet No 34
Side plates on, with countersunk attachment bolts left clear so that they can be removed for servicing.
Side plates
Side plates
This now done the next thing to be done, the top plates look as though they need countersunk bolts as well....
Spot the countersunk bolt
I shall have to work out if these bolts are so visible.
Onwards!
Steve Stuart
Re: Comet No 34
I have decided to turn the whole issue of securing the top plates around by using the bots that secure the Mudguards to secure them in place. Plus I have made them so that they can be relatively easily removed for adjusting the suspension, the aluminium angle is slotted for that purpose.
All great fun, that is why!
Steve Stuart
Re: Comet No 34
Life has a habit of slowing things down, I have been tackling the rear plates. The major thing was to duplicate the Cromwell derived rear plate that has no exhaust holes, install the bolt heads for other details. The other issue was to replicate the angle iron that is welded to the top edge which has the retaining lugs for the Exhaust Cowls.
Job nearly done:
Rear Plates
Rear Plates
The question now is fabric paint or Milliput for the welds? The ancilliary is what make of fabric paint and where to find it?
Tim Page
Has liked: 40 times
Been liked: 471 times
Re: Comet No 34
Post by Tim Page »
Fabric paint for weld lines?
Not heard of that before.
Would be interested to see an example of this method.
Has liked: 1040 times
Re: Comet No 34
Steve, Tim
I've posted about fabric paint a few times, including:
http://www.armortek.co.uk/Forum3b/viewt ... &start=360
http://www.armortek.co.uk/Forum3b/viewt ... &start=750
I then did an update with a new source of material to replace the one Fabrice le Roux originally recommended here:
http://www.armortek.co.uk/Forum3b/viewt ... 527#p55527
I'd recommend fabric paint over Milliput now having use it a lot on my Cent build. It's much quicker and easier to use and above all, it gives much more refined results in smaller areas. I'll still use Milliput for the bigger structural welds but for fine detail, i.e. the majority of welds, I'll use fabric paint.
Steve Stuart
Re: Comet No 34
Thank you for the information Stephen. I have walked around to Hobby Craft and bought there a tube of the Tulip 3D paint which I am seeing how it performs. I will also get some of the Jaquard 3D paint as the Tulip paint does seem a bit thin. However the weld I am trying simulate does need some thing les bulky than Milliput. Once it has dried I will spray it over and put the photo up on the Forum.
Steve Stuart
Re: Comet No 34
Well one Comet post deserves another! Mudguards have been entertaining me for a while. I thought the side plates had enough bolts, but the mudguards have involved a whole load more.
The front had new full width hinges and then remodelled arms, now with two sides. The forward part had the 'angle iron' edge fitted to it.
The rear had the side plates added and then the steps on the rear of the mudguard remade and soldered in place, all fun and games, but worth the hassle as it now avoids the bolts! I will be forever grateful to Derek for telling me that steel can be soldered.
I hope to move on the wheels, and drive sprockets, necessary to do before fitting the mudguards for real.
Steve Stuart
Re: Comet No 34
Mudguards nearly there, but the drive spocket centre cover needed tweaking to have the three securing bolts, but practicality means that the 5mm cap head bolt is replaced with a counter sunk bolt that is seated on a plug to ensure the head sits at the correct level. The shape is not quite convex enough on the top, but at a glance it ought not to worry too many people too much!
Comet Drive Sprocket Centre Cover
Having done the Comet, the Cromwell demanded attention. 8)
Marco Peter
Has liked: 1539 times
Been liked: 798 times
Re: Comet No 34
Post by Marco Peter »
You showed these to me - great to see the end result!
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Re: Comet No 34
Real or fake? One for Phil, if non-Wehrmacht ist erlaubt darueber.
