Hi Fellas.
I originally mentioned this on the Berg build but thought I would follow Derek's thread.
I have been using an etch primer that I have found to be a good alternative to Upol acid 8 and quite a bit cheaper at under £8.00p!! I have found it to be just as good as the Upol in my opinion. here are your details.
Autotek
Professional.
Etch primer.
500 m.l. can with a much better than normal nozzle giving results far closer to a full sized gun . . . in my opinion.
The shop is local to me and I went in the ask if they would deliver and they will, so here are the details you will need.
http://WWW.mastrpart.co.uk
Mastrpart motor factors Ltd.
Parts hotline 01524 846461
Email:
info@mastrpart.co.uk
Mastrpart Ltd
Northgate,
White Lund Industrial Estate.
Morecambe.
LA3 3BH.
Hope this helps out, like I say I like it and they are pretty helpful in the shop, but they do not mix paint at all . . . but from the same range you can get grey primer yellow high build as seen on my models red lead black and white gloss.
Cheers Paul
