King Tiger Build
Fredrik Jorgensen
Been liked: 1 time
Post by Fredrik Jorgensen »
Lovely to see your progress Simon. The beer can profiles is a strike of easy thinking....ME was goin for the brass one heheh, now skipped ofcourse.
I like the shackles but im not sure if the bolt should be there.
I have asked the oracle Per about it and most seemed to have the splitpin type attatched. But ive seen the ring type pin aswell.
i might be wrong.
Btw have you decided on a perticular one yet, i love your paintwork so just wanted to know:).
Fredrik
steve williams
U shackels
Post by steve williams »
Hello,
Your builds looks great. Where can I get some of those U-shackels. They look great.
Steven
steve williams
U shackels
Hello,
Steven
Been liked: 1768 times
hi steve,
steve winstone supplied my u-shackles,you have the choice of two different types he makes,pin or bolt ,contact him on steve.winstone@sky.com
he does produce superb parts,
simon manning
steve williams
Thanks a lot Simmon. These shackels really complete the look espically on the front.
How's your build comming?
wheel marathon,i have enjoyed this part of the build.828 bolts later,each wheel and hub re-drilled with the winstone correcting template,i used 30 mm long 7ba small head with 5mm of 7ba thread on the bolt end,this thread offered much more strength than the 8ba i used first,e.k.p.supplied the bolts and did a lovely job on them,when bolted together using this method the wheels are very sturdy and your adding one more fixing aswell,hope this of some use to others
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Simon,
So very cool! 8) Your wheel looks like the real thing!
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Excelent job Simon, and the paint work is superb
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Great detail Simon, I bet that took a lot of determination and Patience, but the results are outstanding, keep up the good work
regards Jeff
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Superb work and what a result for your efforts. I thought that the finished wheel was a shot of a full size wheel showing the bolt pattern!!
Allan Richards
Steve Norris
Has liked: 8 times
Simon,
How about a few words on your painting technique, I would love to Know how you get such a great finish.
hi steve,
i will have to think about a reply,i find the painting easy, its the metal work that i struggle with,
simon manning
Has liked: 161 times
Been liked: 849 times
Great detail on the wheels Simon they look fantastic. How do you work on 3 models at once! :?
i have been working on the vents,but not much else while the summer is here,7ba bolts used around the front hatch plate,7ba small head used on the rear engine deck,i bought 2mm plastic railway numbers and letters and glued them on to the vents as cast numbers,some extra photos here for any interest.
regards simon manning
