so far so good,
outer nuts and bolts 7ba x1/2 "hex standard steel bolts+7ba standard steel nuts,12 per wheel,nut and bolt.
middle section of wheel 15 nuts and bolts,7ba small head shank x30mm long with 6mm of 8ba thread on the end for 8 ba nut,this combination allows you to copy the correct nut and bolt pattern if you want ,i will use the template to correct the missing holes ,the 30 mm bolts replace the kit ones supplied the 7ba shank gives the same thickness as the 2.5mm and fits well in the holes provided,this nut and bolt size look quite good.
the inner wheel hub,i used 10ba x 1/4 hex steel nuts and bolts x 6 of each per hub.
e.k.p.supplies made all the nuts and bolts and the 30mm long specials ,they will make more no problem if required.
clear as mud. simon manning
