Jagdpanther no 13
David Brady
Has liked: 213 times
Been liked: 840 times
Re: Jagdpanther no 13
Post by David Brady »
Bracket added to secure the mud guard, one more to make! need to order some 1mm drills, as the ones I had made drilling through the steel mudguard a tricky task.
David Brady
2nd side completed, simple enough 2nd time round but little jobs like this still take a few hours.
David Brady
Some progress
I lowerd the grills by adding some washers between the deck and the grill
Width of raised heater end increased by 5mm
Fitted the detail to secure the fan grill covers
Not wide enough
Not wide enough
Much better
Much better
DB
Has liked: 161 times
Been liked: 830 times
Very nice details David - great progress.
David Brady
Thanks Bob
Some more progress
Removed the bottom edge and shapped to look more  like the original, just the cross to the front to add.
Made the bracket that holds the rear light.
Made the starter bracket, done the best I could without realignment, hole aligns for the crank handle.
David Brady
Some work on the rear reflector, reflector started off as a SW part, this was reduced to what you see, bracket was made to mount.
David Brady
Armored water and fuel covers on the early kits when compared to the books was notacable in the wrong position.
I removed the bottom of the kit parts to fill the hole (filler to add) new position is much better when compared to the book - (fasteners detail to add)
I'm hoping someone will produce these with removable lid and inside detail.
DB
Will Roberts
Has liked: 8 times
Been liked: 29 times
Post by Will Roberts »
Hello David,
I have moved these covers on my Early Panther G (2006 Panther) and you will also note that the bolts fixing the engine cover were recessed. I have posted a question about the size of these fasteners but nobody has replied. I am considering either using M2.5 or M2 hex bolts. What size have you used?
Many thanks,
Will.
David Brady
Hi Will,
These are 8ba (4mm across the flats) later tanks did not have these recessed.
David Brady
Fitted the reflector... looked to big! modified as pictured
