Hi All,
Suspension rail and battery tray fasteners countersunk, and weld line to simulate two pcs hull plate cut in then weld applied.
Jagdpanther no 13
- Has liked: 200 times
- Been liked: 796 times
Re: Jagdpanther no 13
- Been liked: 1721 times
Thanks Simon, I've set myself a goal to get this on its tracks in the next week or so.
DB
DB
Tim Catton spade and fire extinguisher fitted, all parts secured down with 10ba fasteners countersunk slotted
DB
DB
The rear deck was the last piece to disassemble and clean, the usual rust and thick paint kept me busy.
- Has liked: 146 times
- Been liked: 806 times
Small job today, added some fasteners to the forward section of the deck
The front mudguards are slightly to long /should be level with the vertical edge ...a fare amount of work to correct as bolts (outside edge) will also need realignment/ holes soldered up ....is it worth doing?
