Jagdpanther no 13
David Brady
Has liked: 213 times
Been liked: 840 times
Re: Jagdpanther no 13
Post by David Brady »
Hi All,
Suspension rail and battery tray fasteners countersunk, and weld line to simulate two pcs hull plate cut in then weld applied.
Looks good Dave, simon.
David Brady
Thanks Simon, I've set myself a goal to get this on its tracks in the next week or so.
DB
David Brady
Some progress.
More milliput welds applied before the red oxide
Mike Stannard track hangers fitted and previously fitted Steve winstone jacking block aligned to a more accurate position
Enjoyed laying down some red oxide with my airbrush- practice makes better
DB
David Brady
Tim Catton spade and fire extinguisher fitted, all parts secured down with 10ba fasteners countersunk slotted
DB
David Brady
The rear deck was the last piece to disassemble and clean, the usual rust and thick paint kept me busy.
Steel deck after a good few hours back in a primer
Grills got the cast texture and (Small grills) modified
Line cut in to simulate two pcs section
Assemble with 8ba fasteners and Mike stannard lock taps, some bolts that hold the cast grills in place have been countersunk (these will be filled later) to achieve closer to the real tank bolt configuration
Steve Winstone gun cleaning tube and Mike's Grills temporarily placed to get an idea of how its going to look.
Has liked: 161 times
Been liked: 830 times
Lovely details David, really starting to "pop".
David Brady
Small job today, added some fasteners to the forward section of the deck
The front mudguards are slightly to long /should be level with the vertical edge ...a fare amount of work to correct as bolts (outside edge) will also need realignment/ holes soldered up ....is it worth doing?
David Brady
Hi All,
Front mudguard modified, thanks for the advice Steve Tillett.
Around 8mm cut away from the front, fasteners repositioned
Looking much improved
Modification went smoth except for the Small cut out section ( I cut this incorrectly) had to build it back up with silver solder.
David Brady
That's other side completed...check a few times and then cut.
David Brady
Couple of little jobs completed today
Revisited and finished of the side rail with additional fastener added.
Tow cable post position moved
Looks a little more like the above
David Brady
A few hours spent after work
David Brady
Been busy the last few days, tyres cleaned and refitted, along with bearings, just a few wheels to add the fasteners to finish.
The amount of work it's taken to bring this Jagdpanther back to this stage is emence (I wiill not take on another refurb) just my tiger 1 late to finish (this was also a full strip down) and a sturmtiger! thankfully the sturm was a bare metal build.
Refurbs are two jobs, take it apart, like restoring an old car, but can be satisfying, keep at it Dave, only four more to doo, regards Simon.
Chris.Marshall
Been liked: 35 times
Post by Chris.Marshall »
Agreed, a refurb done right is a BIG job..... The cleaning and removal of old finishes can take ages. But remember ,..... " The power is in your oven gloves ! " Love the slogan on the box..... :D :P " Epic Week......
Chris.
