2024 Jagdpanther No43 build log.
Re: 2024 Jagdpanther No43 build log.
Time for some paint, Temperature has warmed up a little so can start applying,
Will try and put in the pictures what paints and materials we use, Once the underside has dried will turn over and start primming the top side and color the inside,
Regards, Chris.
Regards, Chris.
More hull painting,
Thanks chris.
Once all dry will start on filling over fasteners not to be seen, Dummy welds added and texture surface applied, Again will show pictures as we go along on method and products used, Also can now start adding the motion pack, Thanks chris.
As the cold spell continues and not ideal for painting etc carried on with installing the motion pack,
Hopefully warming up next week so we can continue with painting etc,-
- Has liked: 218 times
- Been liked: 183 times
Hi Chris
Nice neat layout and good to see the new motor set up.
Regards Derek
Regards Derek
Some more progress, Again anything you want to know or advice please feel free to ask,
Next stage will be applying the base colors.-
- Has liked: 258 times
- Been liked: 187 times
A useful device, who is the supplier and what is it's name so I search for it?
Thanks Steve
Thanks Steve
Evening Steve,
Try searching for DIY craft extruder, eBay is your best bet,
Regards, Chris.
Regards, Chris.
- Been liked: 7 times
Chris,
Thank you for posting! Best new modeling tool for 2025.
Dan
Dan
- Been liked: 603 times
Hi Chris,
The extruder is a good idea, thanks for sharing,
i orderd one.
Best regards Yves
i orderd one.
Best regards Yves
Applying paint,
Difficult for me to explain but hope the pictures make sense, There are a lot more stages to go but this is the start of building up the weathering effect, Next will be the camouflage pattern,-
- Has liked: 801 times
- Been liked: 69 times
This is very helpful Chris, the photos and explanations are spot on. Thank you for sharing your work with us.
Camouflage anyone,
A lot more ageing to be done, side skirts to be fitted and stripes applied,Re: 2024 Jagdpanther No43 build log.
More progress with the weathering,
Hope this is being of some help to other builders,-
Hi Chris
Looking good .
Regards Derek
Looking good .
Regards Derek
