LEO-2A4
Stanislav Yanev
Been liked: 106 times
LEO-2A4
Post by Stanislav Yanev »
Hello
We all get the same boxes so I'll spare you that. I thought I'd start where I thought I could do something different from the standard build.
Anything I do as changes from the standard model we all receive is entirely my responsibility,no one is obligated and I am not urging anyone to make changes,some modifications require additional knowledge without which you may damage parts which are 100 percent usable, who is not sure of his actions, it is better to stick to the instructions of the Armortek
I will start with SPROCKET ASSEMBLY. I will add two details to stop the axial movement of the axle with the gear
Тhe sequence of the photos shows the order of manufacture
Тhe video shows the end result
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:02 pm, edited 1 time in total.
Been liked: 1843 times
Re: LEO-2A4
Excellent engineering Stanislav, the pictures are brilliant too, looks a very robust system. 8)
Stanislav Yanev
Re: LEO-2A4
Thanks John
Мy build will be slow because I'm limited by time but I hope it will be interesting and useful for others :) :) :)
Stanislav Yanev
Re: LEO-2A4
Hello
A little free time and here is the result. New RUBBER STOP. In the pictures is the prototyping process then the molds and then the final result
Armortek and my
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:10 pm, edited 1 time in total.
Re: LEO-2A4
Did you recast the rubber bump stop or machine a larger one to size? 8)
Stanislav Yanev
Re: LEO-2A4
a completely new detail,it is slightly larger and with a different shape that comes as close as possible to the original
Stanislav Yanev
Re: LEO-2A4
Hello guys
A few photos from the working moments. The first few photos are of the part that will make the connection between the clevis and the recoil mechanism
Turning, drilling and turning again, then thread threading
Test whether everything is ok with the thread - Perfect
Next is the making of holes on the part and then cutting the thread
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:18 pm, edited 1 time in total.
Stanislav Yanev
Re: LEO-2A4
I had to put to lathe machine and drill the gear to fit the original details , the picture shows before and after
Аgain, creating an axle to match the original kit parts and of course the new gear
Мaking a keyway will be a real challenge for me I'll leave it for now until I decide how
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:20 pm, edited 1 time in total.
Stanislav Yanev
Re: LEO-2A4
So there was little time left today to make the keyway
I made a few samples of the assembly
I also made a tension roller for the belt,I haven't decided yet what kind of motor I'm going to use but the roller is a roller with two bearings
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:23 pm, edited 1 time in total.
Stanislav Yanev
Re: LEO-2A4
One more thing I want to change for more detail like the original
the first photo shows the original, and the following are the stages of my attempts to recreate it
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:29 pm, edited 1 time in total.
Stanislav Yanev
Re: LEO-2A4
Hello guys
Because the material I have is of a size in which I can mill one detail on both sides,but it is not enough to cut it into two pieces first, so it turned out like this from the picture
then separate the two parts from the main block
next comes cleaning the details and entering the correct size, another threaded hole and finally the final detail
Last edited by Stanislav Yanev on Mon Nov 11, 2024 4:35 pm, edited 1 time in total.
Stanislav Yanev
Re: LEO-2A4
Here is the final result
Мoving forward with the next detail , I just tried but the direction is this
Last edited by Stanislav Yanev on Tue Nov 05, 2024 4:23 pm, edited 1 time in total.
Stanislav Yanev
Re: LEO-2A4
Hello
My daughter pointed out to me that I had missed an obvious detail and I had to redo the detail ,on the left is before and on the right is after
Stanislav Yanev
Re: LEO-2A4
Hi
Guys I need some help with info. I can't find clean pictures of Bump Stop B anywhere. in the photos I can see that they are of two types, but in how many and in which places they are, it is difficult to understand.
this is the one
and this is the other one
Andre Meylan
Has liked: 802 times
Been liked: 362 times
Re: LEO-2A4
Post by Andre Meylan »
Hi there,
I think these photos could be helpful.
Best regards, Andre
