Churchill drive sprocket assembly advice required
Forum for discussions relating to the Churchill
Gary Richardson
Has liked: 787 times
Been liked: 1877 times
Post by Gary Richardson »
Hi all
Just wanted to run this past the Churchill builders who have already completed the drive sprocket assembly. I e-mailed Kian and Monique but suspect they are very busy getting ready for Tankfest so thought I would ask my fellow builders. I am going to Tankfest Friday so may get the chance to ask Kian then :D
Referring to page 14:-
The driven gear EX0220 has the bearing Loctited to the shaft and also the gearbox casing, similar method as the Tiger and I am assuming green Loctite is used. The outer bearing 6000-2RS apparently is also Loctited to the shaft and EX0225 ( says EX0224 on page 14). My problem is I do not see how you can get to the taper lock or remove EX0224 once you have Loctited the bearing to do adjustments, maintenance etc.
I am thinking about not Loctiting the inner race of the 6000-2RS bearing but the shaft is quite a loose fit and could just revolve inside the inner race causing wear.
Any thoughts you may have would be gratefully received as this is holding up completion of the lower hull.
Gary
David Skeldon
Has liked: 33 times
Been liked: 312 times
Re: Churchill drive sprocket assembly advice required
Post by David Skeldon »
Hi,
My outer bearing is not glued to the shaft so it can easily be removed, when the tracks are tensioned it’s unlikely that the shaft will spin in the bearing unless the bearing seizes, you could add grease so if it did it should not wear, But then my tanks do not do a lot of miles. Hope this helps.
Has liked: 1481 times
Been liked: 1687 times
Until you sell them to me (or Allan) :lol: :wink:
Steve Stuart
Has liked: 263 times
Been liked: 195 times
Post by Steve Stuart »
The Cromwell has done the most of the lot, two great swans to Holland (Militracks) as well....
David Skeldon
Has liked: 33 times
Looking at Churchill tanks they don’t seem to have tyres on the rear drive sprockets
Andy Cameron
Been liked: 58 times
Post by Andy Cameron »
Hi Gary
Can I ask what your decision was regarding loctiting the bearings, I am approaching this stage (when I figure out CP1233 M5x? Fixing Bolts to use) and quite like the idea of not using Loctite on the bearings when possible.
Andy
Gary Richardson
Hi Andy
I did not Loctite the outer shaft to the bearing. If you do you will not be able to get to the taper lock later on should adjustments or maintenance be required. This also proved the right choice as I had to realign the drive wheels once the bogies were in place.
Gary
Andy Cameron
Thanks Gary I will do the same
Andy
Chris Singer
Has liked: 11 times
Been liked: 39 times
Post by Chris Singer »
Are there any secrets to getting the various metal panels that unite to support the sprocket wheel into perfect alignment? I find with everything connected and tightened up the Sprocket wheel binds severely and is not at all free running…?
Gary Richardson
Hi Chris
I also had a problem lining them up. Leave the button head screws that connect EX1008, EX0119 and EX0216 just finger tight and revolve the sprocket while gently moving the rear plate EX0224, once it is spinning freely start tightening up the button heads. It took me several attempts plus a bit of fettling where EX0224 meets the main pannier end to achieve this. I think the main problem is the pannier sides are so long that even a tiny induced angle when fitting them disproportionally affects the position at the rear of the pannier.
Neither of my pannier sides are exactly symmetrical despite a lot of effort to make them so. You may find it helpful to have a second pair of hands available to tighten the button heads while you move the plate.
Hope this helps.
Gary
Chris Singer
Has liked: 11 times
Thanks Gary! you were right about the angle of panniers - I loosened everything off then added the top bracing longitudinal supports, tightened everything up again checking spinning as it went and now we're good!
