Just wanted to run this past the Churchill builders who have already completed the drive sprocket assembly. I e-mailed Kian and Monique but suspect they are very busy getting ready for Tankfest so thought I would ask my fellow builders. I am going to Tankfest Friday so may get the chance to ask Kian then
Referring to page 14:-
The driven gear EX0220 has the bearing Loctited to the shaft and also the gearbox casing, similar method as the Tiger and I am assuming green Loctite is used. The outer bearing 6000-2RS apparently is also Loctited to the shaft and EX0225 ( says EX0224 on page 14). My problem is I do not see how you can get to the taper lock or remove EX0224 once you have Loctited the bearing to do adjustments, maintenance etc.
I am thinking about not Loctiting the inner race of the 6000-2RS bearing but the shaft is quite a loose fit and could just revolve inside the inner race causing wear.
Any thoughts you may have would be gratefully received as this is holding up completion of the lower hull.
Gary
