speakers on the Easy 8
John Burden
Has liked: 5 times
Been liked: 12 times
Post by John Burden »
I have been playing around with the 2 speakers from the Audio Option pack for the E8. Not found the perfect location, yet I am leaning towards facing up below the engine grills.
What have others done?
Andy Walker
Has liked: 134 times
Been liked: 137 times
Re: speakers on the Easy 8
Post by Andy Walker »
I've put mine under the engine grill but one each side of smoke unit facing inwards.
Erik Dries
Has liked: 74 times
Been liked: 14 times
Post by Erik Dries »
this is what i have done
John Burden
Has liked: 5 times
Eric that's a pretty fancy setup you've done. Very nice
Antony Selwood
Has liked: 14 times
Post by Antony Selwood »
Very neat installation Eric, what type of board are those components mounted on? and how is it secured to the tank sides?
Erik Dries
Has liked: 74 times
Hi,
It is a 3d printed tray, The the speakers are mounted in a completely printed speakerbox, this is mounted over the smoker. The main tray exist of four levels, three below the one you can see, all the electronics are placed there. the front piece around the battery is just for the looks and to guide some wires to the front. For now it is secured by gravity and the bolt heads from the sponsoon mounting. It can not move from side to side because of the fit.
I made a small miscaculation with the space for the turret motor and had to remove material manually, as the print was about 7 days i did not wanto do it again. The print material is ABS.
Been liked: 1842 times
Brilliant. That's next level internal lay out :mrgreen:
GlenStenhouse
Has liked: 17 times
Been liked: 26 times
Post by GlenStenhouse »
No room for the smoke pack?
