Suspension arm angle
Online
Paul Sparkes
Has liked: 97 times
Been liked: 243 times
Post by Paul Sparkes »
I’m chasing a few problems with the drive train on the Jagdtiger.
On inspection some of the torsion bar end were loose and the angle had changed.
The manual says set to 25 degrees, is the KT the same angle? I see some mention 35 degree. Is there any info to support the angle change or what works better.
222 scout car
Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Re: Suspension arm angle
Post by Brian Ostlind »
I did set up my king Tiger with a higher angle just to get the slack in the tracks out because I couldn’t tighten the idler far enough. That worked well for me.
Michael Allen
Has liked: 1039 times
Been liked: 79 times
Post by Michael Allen »
Brian
Given all your KT experience what angle would you now recommend. I’ve got to install mine soon and would appreciate your guidance. Many thanks
Mick
Brian Ostlind
Michael Allen wrote:
Sat Mar 25, 2023 7:50 pm
Brian
Mick
I was around 35 degrees but I never measured exactly.
