I’m chasing a few problems with the drive train on the Jagdtiger.
On inspection some of the torsion bar end were loose and the angle had changed.
The manual says set to 25 degrees, is the KT the same angle? I see some mention 35 degree. Is there any info to support the angle change or what works better.
Suspension arm angle
- Paul Sparkes
- Has liked: 98 times
- Been liked: 243 times
222 scout car
222 scout car
- Brian Ostlind
- Has liked: 976 times
- Been liked: 2068 times
Re: Suspension arm angle
I did set up my king Tiger with a higher angle just to get the slack in the tracks out because I couldn’t tighten the idler far enough. That worked well for me.
- Has liked: 1040 times
- Been liked: 80 times
Brian
Given all your KT experience what angle would you now recommend. I’ve got to install mine soon and would appreciate your guidance. Many thanks
Mick
Mick
- Brian Ostlind
I was around 35 degrees but I never measured exactly.Michael Allen wrote: ↑Sat Mar 25, 2023 7:50 pmBrian
Mick
