I am in the process of setting up my Taranis X9D PLUS 2019 transmitter for the Tiger and would like some advice on stick configurations and when to use self centre springing and ratchets. I have changed the transmitter from mode 2 to mode 1 (throttle right) for single stick driving and have set the ratchet tension on the right hand stick for main motors forward and reverse and left it spring centring for left and right. Then I starting wondering if the stick should be completely self centring so that the tank would stop if the stick was released as a safety function.
On the left hand stick do you keep the ratchet on for gun elevation and the spring centring for turret right and left ?
I realise people probably have their own preferences but as this is my first tank I thought it best to ask as nearly all the advice on the forum is about the programming rather than the mechanics of setting up a transmitter.
As usual any advice will be gratefully received
Gary
