Spektrum dx9
- Has liked: 116 times
- Been liked: 117 times
Spektrum dx9
Just wondered if anyone has setup a Spektrum dx9 transmitter for their tank? I have been trying but with no luck so far. Any advice appreciated.
- Has liked: 1035 times
Re: Spektrum dx9
yes, I followed the instructions as closely as possible but it appears the DX9 has a slightly different menu to the other two transmitters.
- Has liked: 10 times
- Been liked: 224 times
- Tim Page
- Has liked: 40 times
- Been liked: 471 times
Re: Spektrum dx9
Ive been using a DX9 for the last 2-3 years with all my models without any problems.
Re: Spektrum dx9
I followed the forum instructions to setup the tx / receiver but cant get motors to work. I managed to do it with a DX6i, but not DX9 Black. I'm not sure if its a faulty rx, but it bound to the tx okay.
- Tim Page
Re: Spektrum dx9
Sounds like you might not be bound correctly.
Try re-binding RX/TX
Good luck
Good luck
Re: Spektrum dx9
Have you plugged servos in to the each channel to try them ? Is the light on the RX on solid ?
Dennis
Dennis
Re: Spektrum dx9
Yep, nothing works with the DX9 / Rx combo......yet works fine with the DX6i / Rx combo. Both Tx / Rx bind fine with the flashing light going solid. I suspect the Rx I'm using with the DX9 may be faulty, but I dont have another that works with it.Dennis Jones wrote: ↑Wed Apr 28, 2021 11:15 amHave you plugged servos in to the each channel to try them ? Is the light on the RX on solid ?
Dennis
- Tim Page
Re: Spektrum dx9
Hiya, In that case the only other thing that springs to mind is that maybe you have the leads into the RX the wrong way up.
The black wire should be on top.
Re: Spektrum dx9
I have at last got the DX9 Tx and AR9020 Rx working. It appears this Rx wont work unless 2 satellite Rx are connected to it
