Spektrum dx9
Andy Walker
Has liked: 125 times
Been liked: 131 times
Spektrum dx9
Post by Andy Walker »
Just wondered if anyone has setup a Spektrum dx9 transmitter for their tank? I have been trying but with no luck so far. Any advice appreciated.
Has liked: 1037 times
Re: Spektrum dx9
There's a whole Knowledge Base Topic on the subject here:
viewtopic.php?f=34&t=5795
Andy Walker
Re: Spektrum dx9
yes, I followed the instructions as closely as possible but it appears the DX9 has a slightly different menu to the other two transmitters.
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Re: Spektrum dx9
Post by Dennis Jones »
What problems are you having Andy ?
Dennis.
Tim Page
Has liked: 40 times
Been liked: 471 times
Re: Spektrum dx9
Post by Tim Page »
Ive been using a DX9 for the last 2-3 years with all my models without any problems.
Andy Walker
Re: Spektrum dx9
Dennis Jones wrote:
Tue Apr 27, 2021 11:04 am
Dennis.
I followed the forum instructions to setup the tx / receiver but cant get motors to work. I managed to do it with a DX6i, but not DX9 Black. I'm not sure if its a faulty rx, but it bound to the tx okay.
Tim Page
Has liked: 40 times
Re: Spektrum dx9
Post by Tim Page »
Sounds like you might not be bound correctly.
Try re-binding RX/TX
Good luck
Dennis Jones
Has liked: 10 times
Re: Spektrum dx9
Have you plugged servos in to the each channel to try them ? Is the light on the RX on solid ?
Dennis
Andy Walker
Re: Spektrum dx9
Dennis Jones wrote:
Wed Apr 28, 2021 11:15 am
Dennis
Yep, nothing works with the DX9 / Rx combo......yet works fine with the DX6i / Rx combo. Both Tx / Rx bind fine with the flashing light going solid. I suspect the Rx I'm using with the DX9 may be faulty, but I dont have another that works with it.
Tim Page
Has liked: 40 times
Re: Spektrum dx9
Post by Tim Page »
Hiya, In that case the only other thing that springs to mind is that maybe you have the leads into the RX the wrong way up.
The black wire should be on top.
Andy Walker
Re: Spektrum dx9
I have at last got the DX9 Tx and AR9020 Rx working. It appears this Rx wont work unless 2 satellite Rx are connected to it :roll:
