Tiger 1 late variant breech
Has liked: 763 times
Been liked: 1739 times
I have been following John's amazing build of the Tiger 1 breech (viewtopic.php?f=6&t=2922&start=435). I was always interested in 3D modelling the said breech but could never find enough information / dimensions to make a decent one. Recently on John's build, Chang posted an interesting link (http://metspra.ru/).
I have never seen this site before and was amazed at the useful information I could find there. Best of all it has a set of drawings regarding the breech and all the gun components. Unfortunately all the drawing are in 1/16 scale. Hence the reason why I am posting here and not in the Tiger 1 forum. I decided to start 3D drawing the various components in 1/16 scale. I can always upscale it to 1/6 scale when required.
I am not going to flood the forum with images. Instead if you follow this link (Link removed) it should take you to a web based 3D viewer and view the progress there. Hopefully it will work. One can view various components there. I will try to keep this link active during the drawing process.
Last edited by Vince Cutajar on Fri Mar 12, 2021 3:57 pm, edited 2 times in total.
Has liked: 123 times
Been liked: 754 times
Re: Tiger 1 late variant breech
Hi Vince,
I was able to open link and view your model. That is a neat feature in F360. I was able to rotate and explode the model. Nice work.
Thanks Bob for your comments. Yes, the web based viewer is a nifty function. I only got to know about it recently and have been testing it with Phil on his Faun build. It is better than sending images of the model. I only hope that it continues to work properly as the file gets bigger.
Steen Vøler
Has liked: 62 times
Been liked: 498 times
Post by Steen Vøler »
Hi Vince
It's is amazing what you can do in 3d :D
cheers
Steen
I've done all the parts pertaining to the breech body. One can use the same link to have a look.
Next to be drawn will be the recuperator and recoil components. Whilst looking at the drawings I noticed something strange. The attachment points of the two cylinders are actually bolted to the two sides of the breech body. I always thought these were welded. Internet search for images of Tiger 1 breech was done and some photos actually showed these attachment points being bolted.
So I guess there were two types of Tiger 1 breeches. Another difference I noticed was that some breech bodies had filleted edges whilst others had chamfered edges. Learned something new today.
Yesterday I finished the breech and cradle. Decided to add the barrel and muzzle brake. I used my own 3D model for the muzzle brake instead of remaking it.
Now I am thinking of adding the mantlet for completeness. I guess I am digging a deeper rabbit hole!! :shock:
Mantlet finished also. I am not going to add further bits and pieces so I am declaring that the model is complete. Enjoyed the challenge.
I will leave the link to the web-based 3D viewer active (give it some time to load as the file is big) for a few more days then I will replace it with a couple of images.
Made a simple animation of the breech block operation. It's a bit rough as holding camera with one hand and operating mouse with the other.
Steen Vøler
Has liked: 62 times
Well done Vince :D
cheers
Steen
I have disabled the link to the 3D web viewer and instead I am posting a few images.
Beautiful CAD model Vince. Your skills have come a long way! That gun looks great.
B
Thanks Bob. I guess practice makes perfect. As I am rarely going to the workshop I tend to spend a lot of time on CAD.
