Sprocket vs Taper Lock Bush.
Tom Wittstock
Been liked: 18 times
Post by Tom Wittstock »
All another question, It has been awhile since my last build but could someone explain to me how the Taper Lock Bush, grub screws, Driven Gear and Sprocket work together. I did a dry fit with all of the above and the Sprocket wheel is still loose and slides right off What aim I'm doing wrong?? :shock:
Thanks again
Has liked: 1485 times
Been liked: 1695 times
Re: Sprocket vs Taper Lock Bush.
Tom Wittstock
Thanks Adrian, I'm good to go!
