Viper 10 ESC for Turret won’t program
michael didonato
Been liked: 4 times
Post by michael didonato »
Hello, I’m having a little problem keeping my HV Viper 10 speed control programed. It seems every time I shut my model off, I would then need to reprogram the esc. The issue I’m having now is it won’t let me program it. I hit the program button promptly when turning on power, It goes to program mode, (green led)I push fully forward and return to neutral (red led) I then pull throttle back and return to neutral, then all 3 leds start flashing together. Please I been going crazy for days now and nothing seems to work. I do have the speed control set to correct battery type. Regards,Michael
Has liked: 1492 times
Been liked: 1699 times
Re: Viper 10 ESC for Turret won’t program
Has it ever worked correctly ?
What transmitter/receiver are you using it with ?
What happens if you don't calibrate it ?
michael didonato
Been liked: 4 times
Ok, I seemed to get it calibrated. I didn’t notice that I had one of the switches was in the wrong position in which effected the lever end points that are beyond recognition for the ESC. The ESC still won’t save my parameters, I have to reprogram eveytime I switch on model. I am using futuba T8J
