Just like the original tank, my model will evolve and will be upgraded with different options. Yes, it will mean a few mods. I've completed a few already, decorative and automotive. Now is the time to give some thought to the drive system even before it actually gets fitted, it'll be so much easier to work on being an open shell.
Funnily enough I'm going to call the motive upgrades X Y & Z, not historically correct but there are three stages. so why not.
The options packs provide the model with some sophisticated electronic equipment and some very powerful motive power, It has to be to push the brute about. The added rubber pads on dry hard surfaces will have far more traction than the slippery alloy track of the big cats.
Torque is the Friend and the Enemy, harness it and it is your Friend. Let it loose and it will knock your teeth out.
I do have limited tooling, but I do know if I can keep the tolerances to the minimum, it's possible it will reduce torque stress and with a couple or three simple mods I think I can get maximum torque to the sprockets were it needs to be.
So, plan X, I'll be adding support to the very heavy motor and gearboxes and lock them down This will reduce any twisting motion on the three M5 mounting bolts when the drive takes up and during direction changes.
Plan Y,Gearbox, Set end float to the bare minimum, there are very few components in the gearbox. To get a good low ratio output (High torque) the component teeth will be very small, to prevent our friend torque trying to push the teeth apart, a tiny end float will to be setup and maintained.
I'll have fun with this. Too little end float and the gears will wear out or break up, too much end float and the teeth will skip over each other with the cold rasping noise to freeze the heart.
Plan Z, To improve output shaft stability, I've worked out a way to add an extra bearing fitted inside the motor gearbox mount spacer. It will mean splitting the output shaft extension pinion and adding a machined support sleeve, but carefully setup, it should improve alignment and take away some of the stress from the inner original shaft support bush.
I cannot advise others to do as I am doing, sadly access the the machining requirements will also be restricting, though all the parts are there.
It's a bit like the old Morecambe & Wise piano sketch note parts "all the right parts are there". Classic
From the outside this looks like a similar type motor and gearbox we use. Yippy Ki yay
