white metal
yves mouton
Been liked: 741 times
white metal
Post by yves mouton »
Hello,
I have a question about white metal,
the small tow cable of my panther is broken ( one of the ends )
Is there a solution to fix that?
Best regards Yves
Tom Opsommer
Been liked: 13 times
Re: white metal
Post by Tom Opsommer »
Some very carrefull 2 componend epoxy glue could do the trick. But for the rest white metal is not very fixable
mark lawson
Has liked: 2522 times
Been liked: 445 times
Re: white metal
Post by mark lawson »
Who made the cables? If you contact the manufacturer they should be able to supply a replacement end
RAG Militärmodellbau
IG Militärmodellbau
yves mouton
Re: white metal
Thanks Tom
Hello Mark, the small towcable comes from Mike Stannard.
Best regards Yves
Has liked: 1040 times
Re: white metal
Yves, if you're careful, you can successfully solder white metal. Use a low temperature solder, plenty of flux and an iron set to below 200 deg C. Don't hold the iron on the metal for too long or you can melt the whole thing. If you can, use a heat sink such as a G clamp to protect the part you don't want heated.
Been liked: 1843 times
Re: white metal
That a "nice to know" Stephen, Thanks. :D
Don't know where you can get hold of asbestos finger ends do you, that last lot of soldering I did was hot hot hot! :lol:
yves mouton
Re: white metal
Thanks for the info Steve
Best regards Yves
