JT in Germany
- Peter Quambusch
- Been liked: 825 times
Re: JT in Germany
After the usual bench testing, a first quick test drive yesterday ....
.... Electronics and servos as well as rear deck and details not yet fixed, as I have to overcome a major problem: . The Tank is toooooo smal The same batteries that fit into Elefant and Kingtiger are too big for the Jagttiger.... Solution: ordered a 48 Ah 24 V LiFePo battery. Will arrive (hopefully) beginnig of next year... Thus time to start with the internal Stug III Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change A bunch of Tiger and Panther variants, a few 88`s and smaler ones like Hetzer, Stug III, etc. and soon a Leo II
- Has liked: 682 times
- Been liked: 273 times
Re: JT in Germany
Yes, the fact that the gun can both traverse and elevate, the recoil mechanism takes up just about the entire casemate, leaving little room for anything else. Amazing really!
You are going to hate your old batteries...
- Peter Quambusch
Re: JT in Germany
Problem is, they are brand new...Christoffer Ahlfors wrote: ↑Thu Dec 10, 2020 7:12 pmYes, the fact that the gun can both traverse and elevate, the recoil mechanism takes up just about the entire casemate, leaving little room for anything else. Amazing really!
- Peter Quambusch
Re: JT in Germany
But while waiting for the new battery to arrive, I decided to go forth with the conversion (upgrade), as described in a previos post:
- Peter Quambusch
Re: JT in Germany
Started assembly of the Jagdtiger transport tracks
That´s what I call "Home Office" Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change A bunch of Tiger and Panther variants, a few 88`s and smaler ones like Hetzer, Stug III, etc. and soon a Leo II
- Brian Ostlind
- Has liked: 956 times
- Been liked: 2034 times
- Peter Quambusch
Re: JT in Germany
Great!!!! Can´t wait to see the results!!!Brian Ostlind wrote: ↑Fri Dec 11, 2020 8:41 pmOuwow is time to start my J.T.K.T.STUG. NOTHING WILL PENETRATE IT.
But still waiting for the Ratte to be shipped over!!
- Gerhard Michel
- Has liked: 3 times
- Been liked: 564 times
Re: JT in Germany
Hello Peter,
glad to read that at the end you also have decided to use LiFes! In my opinion this is the only one power source that fits a modern vehicle; small, lightweight, powerful. Due to the fact that a LiFe battery can be used at 100 % DoD without a significant lack of duty and a lead acid battery only at 50 % DoD, you might have used also some less than 48 Ah. So you will get twice the time of travel!
The 1/6 scale JT has an enormous length of recoil up to 150 mm at the overheat stop (due to the lack of a muzzle brake), if you will use the prototypical length of recoil. When the gun is at its upper fence the barrel will sink deep in the casemate and so need a lot of space in the hull when traversing in this position. Therefore in my so called 'trendsetter' (the Bigtanks JT) I used some lower LiFes with only 36 Ah after having tried the same mighty lead acids you tried. The result is the necessary clearance for the recoil in the hull, a much longer time of travel and last not least 18 kg less weight!
Gerhard
Gerhard
- Brian Ostlind
- Gerhard Michel
Re: JT in Germany
Hi Brian,
I'm not a friend of LiPos for tank models, because these types of batteries may burn, if they are not treated well. LiFes are much more safe in daily use.
Gerhard
Gerhard
- Has liked: 1198 times
- Been liked: 1383 times
Re: JT in Germany
I bet no-one saw that coming
- Peter Quambusch
Re: JT in Germany
Hi Adrian,Adrian Harris wrote: ↑Sat Dec 12, 2020 1:37 pm> The Tank is toooooo smal
I don´t know how that could happen.... I´m sure its Kian´s fault!! I´m sure he scaled it down for me so I get some extra work....
- Peter Quambusch
Re: JT in Germany
Work on the amunition carrier for the JT in progress
:Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change A bunch of Tiger and Panther variants, a few 88`s and smaler ones like Hetzer, Stug III, etc. and soon a Leo II
- Chang
- Has liked: 14963 times
- Been liked: 372 times
Re: JT in Germany
Just thought of an idea for this "Too small" Jagd Tiger:
(1) Replace two speakers into the casemate, then
(2) Move two large batteries backward to the end of the hull, or
(3) Move one backward and the other one forward as much away from the casemate as possible.
(4) There should be enough space for other option packs.
It maybe worth trying ....
Lerh Chang
Lerh Chang
- Been liked: 18 times
Re: JT in Germany
Question for you, did the Jagdtiger require wider tracks then the King Tiger or were they the same as the King Tiger tank?
Thanks Tom
Thanks Tom
