JT in Germany
Peter Quambusch
Been liked: 1045 times
Re: JT in Germany
Post by Peter Quambusch »
After the usual bench testing, a first quick test drive yesterday ....
.... Electronics and servos as well as rear deck and details not yet fixed, as I have to overcome a major problem:
. The Tank is toooooo smal :oops: :oops: :oops: The same batteries that fit into Elefant and Kingtiger are too big for the Jagttiger.... Solution: ordered a 48 Ah 24 V LiFePo battery. :D Will arrive (hopefully) beginnig of next year... Thus time to start with the internal Stug III :D :D :D
Has liked: 746 times
Been liked: 360 times
Re: JT in Germany
Post by Christoffer Ahlfors »
Yes, the fact that the gun can both traverse and elevate, the recoil mechanism takes up just about the entire casemate, leaving little room for anything else. Amazing really! :lol:
You are going to hate your old batteries...
Peter Quambusch
Re: JT in Germany
Christoffer Ahlfors wrote:
Thu Dec 10, 2020 7:12 pm
Problem is, they are brand new... :shock:
Peter Quambusch
Re: JT in Germany
But while waiting for the new battery to arrive, I decided to go forth with the conversion (upgrade), as described in a previos post:
Peter Quambusch
Re: JT in Germany
Started assembly of the Jagdtiger transport tracks
That´s what I call "Home Office" :D :D :D
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Re: JT in Germany
Post by Brian Ostlind »
Ouwow is time to start my J.T.K.T.STUG. NOTHING WILL PENETRATE IT.
Peter Quambusch
Re: JT in Germany
Brian Ostlind wrote:
Fri Dec 11, 2020 8:41 pm
Great!!!! Can´t wait to see the results!!! :D :D :D :D
But still waiting for the Ratte to be shipped over!!
Gerhard Michel
Has liked: 3 times
Been liked: 687 times
Re: JT in Germany
Post by Gerhard Michel »
Hello Peter,
glad to read that at the end you also have decided to use LiFes! In my opinion this is the only one power source that fits a modern vehicle; small, lightweight, powerful. :mrgreen: Due to the fact that a LiFe battery can be used at 100 % DoD without a significant lack of duty and a lead acid battery only at 50 % DoD, you might have used also some less than 48 Ah. So you will get twice the time of travel!
The 1/6 scale JT has an enormous length of recoil up to 150 mm at the overheat stop (due to the lack of a muzzle brake), if you will use the prototypical length of recoil. When the gun is at its upper fence the barrel will sink deep in the casemate and so need a lot of space in the hull when traversing in this position. Therefore in my so called 'trendsetter' (the Bigtanks JT) I used some lower LiFes with only 36 Ah after having tried the same mighty lead acids you tried. The result is the necessary clearance for the recoil in the hull, a much longer time of travel and last not least 18 kg less weight! :mrgreen:
Gerhard
Brian Ostlind
Re: JT in Germany
Is 6s Lipo an option for power?
Gerhard Michel
Has liked: 3 times
Re: JT in Germany
Hi Brian,
I'm not a friend of LiPos for tank models, because these types of batteries may burn, if they are not treated well. LiFes are much more safe in daily use.
Gerhard
Has liked: 1486 times
Been liked: 1695 times
Re: JT in Germany
I bet no-one saw that coming :lol: :lol: :lol: :lol: :lol:
Peter Quambusch
Re: JT in Germany
Adrian Harris wrote:
Sat Dec 12, 2020 1:37 pm
Hi Adrian,
I don´t know how that could happen.... I´m sure its Kian´s fault!! I´m sure he scaled it down for me so I get some extra work.... :shock: :shock: :shock:
Peter Quambusch
Re: JT in Germany
Work on the amunition carrier for the JT in progress
Chang
Has liked: 16571 times
Been liked: 487 times
Re: JT in Germany
Post by Chang »
Just thought of an idea for this "Too small" Jagd Tiger:
(1) Replace two speakers into the casemate, then
(2) Move two large batteries backward to the end of the hull, or
(3) Move one backward and the other one forward as much away from the casemate as possible.
(4) There should be enough space for other option packs.
It maybe worth trying :idea: ....
Regards,
Lerh Chang
Tom Wittstock
Been liked: 18 times
Re: JT in Germany
Post by Tom Wittstock »
Question for you, did the Jagdtiger require wider tracks then the King Tiger or were they the same as the King Tiger tank?
Thanks Tom
